What's the transmission in a '95 2500?
Old 12-27-2007, 02:51 PM
balingwire's Avatar
My father-in-law has a '95 2500 Cummins w/automatic transmission. What transmission is this? He has had a lot of trouble with the transmission kicking down into a lower gear for no reason, or kinda searching for gears. The truck has over 200K miles on it, and the transmission was rebuilt about 50K miles ago. The truck does not see hard duty, so I don't think that the problem is mechanical. What electrical problems can cause this, or is there something mechanically wrong with the transmission?
Old 12-27-2007, 03:33 PM
Troutstrannysvc's Avatar
47RH
Mechanical Govener
Old 12-27-2007, 04:05 PM
piers harry's Avatar
Check out the TPS, it's more than likely the culprit, not the trans
Old 12-28-2007, 01:02 PM
patdaly's Avatar
Mine was the TPS, do a search on here for TPS or overdrive hunting.
Could be as simple as the Alternator making too much electrical noise as well.
If it shifts clean, I would look to electrical issues first.
joebishop23
10-29-2007 10:19 AM
mattsdiesel06
15
01-25-2006 08:39 PM
ALEX516
09-15-2005 09:14 PM
Bigredmachine
06-24-2004 12:36 AM
03CTDCO
11-18-2003 08:11 PM
Quick Reply: What's the transmission in a '95 2500?
