Sponsored by: CARiD
Whats the story with the casting #53?
Old Aug 4, 2005 | 12:21 AM
the_dubster98's Avatar
Question Whats the story with the casting #53?
Hey guys, im looking for a unique swap and have come up with putting a Cummins in a S-10. The reason is, Im a GM guy,.. but love the power of a Cummins...
anyways, i have found a sweet deal, or i think anyways, on ebay.. its a Casting #53 Complete block,.. he says there is a crack below one of the freeze plugs, he also stated that is normal fault with this casting block... was wondering if it would be fixable? can you weld cast? its going for 350 bucks as we speak.. or any other info about that specific engine would be greatly appreciated... thanks
Chris
Old Aug 4, 2005 | 12:25 AM
edwinsmith's Avatar
You might have to stretch the front end out. The Cummins 6 banger is a bit long. The 4 banger version might fit OK though it's still a bit longer than the 4 banger they put in the S-10. Mine has a V-6 and when it goes I'm thinking about putting the 4BT in there.
Edwin
Old Aug 4, 2005 | 12:28 AM
I would have no problem having to "x-tend" or modify the front clip to make it fit.. and would rig up for the cooling system to be in the bed.. I have seen a few pictures of a truck with a cummins in it.. but it was also a SFA truck too..
Old Aug 6, 2005 | 11:03 AM
blackdiesel's Avatar
Registered
awesome, when u get this done, post pics! ive seen a old 30's chevy pickup with a cummins twin turbo. that was one sweet ride
Old Aug 6, 2005 | 12:57 PM
Haulin_in_Dixie's Avatar
A cracked #53 block is junk. You would not pay for one would you????
Old Aug 6, 2005 | 02:08 PM
Dr. Evil's Avatar
Dropping a 5.9L Cummins in an S-10 is likely a much bigger project than you realize. Tons of fabrication there including frame modification. You do know that the engine weighs 1000 lbs??
Steer clear of the #53 - cracked or otherwise.
Old Aug 6, 2005 | 10:05 PM
FrdRdnk's Avatar
Not to be negative, but what good is a cracked block? My neighbor's 01 just developed it's crack about a month ago, it's a 53 block. He was able to get cummins to replace the block for free but wanted over 4 grand for labor. He found a shop that will get the new block and labor for 2800. My suggestion to you would be to get it only if it's a complete engine, assuming nothing else is wrong with it. Then, you can replace the block and have everything else there you'll need. It might be cheaper then getting a good engine. Good luck with the swap, I'd imagine all the suspension would need to be beefed up and the frame possibly too.
Old Aug 8, 2005 | 06:58 PM
hey guys, the idea has been done before..
the fabrication isnt a problem, have plenty of time and space to work on such a big project...
i was inquiring to see if there was some way to fix this crack, if you tore down the whole engine... but i guess there isnt.. cause rebuilding wouldnt be ap roblem either..
Old Feb 3, 2006 | 04:08 PM
MFEUSAF's Avatar
i wouldnt mess with the #53 block. i have one and mine cracked and i tryed welding it and every thing possible and still no good. now i have to replace the block. no fun if you ask me.
Old Feb 4, 2006 | 12:58 AM
Smkndzl's Avatar
for that price and if it was local , I wouldnt hesitate to buy that engine and replace the block, you would be in it for very cheap.
Old Feb 4, 2006 | 12:19 PM
yarddog's Avatar
What about lok n stitch? I thought a lot of people had success with that?
blh1960
23
Dec 31, 2004 12:35 PM
v8440
Oct 21, 2004 01:39 PM
Haulin_in_Dixie
Apr 3, 2004 01:47 AM
RedWhiteDiesel
Mar 8, 2004 09:44 PM
tool
Dec 27, 2003 02:27 PM
