Walbro 392 Question
Old Dec 20, 2006 | 06:43 PM
skymiles's Avatar
Walbro 392 Question
Can any one tell me if I can replace the stock LP with a walbro 392 or 391 pump and use all the stock fuel lines? I am making 9 psi at Idle and about 6 on the skinny. Starting to get concerned.
Old Dec 20, 2006 | 07:15 PM
CTD NUT's Avatar
Not really......you will have to run a return style regulator in the system when using the 392.....and you will certainly have to ditch the banjo bolts in the system in order to let the 392 do it's job. It is a very powerful pump and will be seriously restricted otherwise.
Old Dec 20, 2006 | 07:29 PM
TNfarmboy's Avatar
You will have to cut the fuel line to put the pump inline. you will also need to install a tee and check/bypass valve to bleed the excess fuel back to the tank.
You can use the stock restrictive banjo fittings, but not the stock fuel line. If you are going to fix the inadequate stock setup, then do it right. I tried to save a few $$ and buy some of the parts locally vs from Glacier. It was a waist of my time Glacier has a good setup with everything you need...great guy too! Oh, I also installed a ball valve so I could change the pump pre-filter without getting soaked with diesel.
Check out my pics, I have my check valve set for 16PSI and it never moves
Old Dec 20, 2006 | 07:32 PM
srt20's Avatar
I second getting rid of the banjos. I still have them in with the 392 and can pull it down to 9-10 psi WOT. At idle its around 20psi.
Old Dec 20, 2006 | 08:02 PM
skymiles's Avatar
I kinda figured I would need to have a regulator. I just was not sure if the stock lines would handle it, considering I am running the motor all stock. But I see everybody's point time is money, do it right the first time. Thanks to all for your response.
sheriffav8r
May 23, 2008 06:38 AM
HiJenks
Jan 30, 2007 07:19 PM
Austin'sDodge
22
Jul 30, 2006 09:31 PM
streetsmoker
24
May 7, 2006 12:26 AM
Dodge Demon
Feb 27, 2006 06:47 PM
