Walbro 392 Installed!!!
Old Jun 30, 2006 | 09:19 PM
Austin'sDodge's Avatar
I received my walbro pump today from the ups man. I went right to work installing the new and dismantling the old, failing lift pump. Install went very smoothly. Cranked it up and checked for leaks, backed out of the shop and took it for a test drive. At idle its at 20psi wot 18psi!!!! Finally good fuel pressure. Seems like it pulls slightly harder through the gears.
If you're on the fence about this upgrade I highly reccomend it.
Thanks, Richard at Glacier Diesel Performance.
Austin
Old Jun 30, 2006 | 09:32 PM
team's Avatar
Mine showed up today (friday), going to put it on monday. I am anxious to get it going. My stock lp is dropping down to 3psi at times!
Old Jun 30, 2006 | 09:39 PM
Same here, once it even dropped to 2psi.
Old Jun 30, 2006 | 09:45 PM
nitrousn's Avatar
Where are you placing the pump on the 2nd generations? How noisey is the pump? I have a campaign pump and the vulcan kit i was going to install but have held off because they claim the relocated stock pump is very noisey under the cab.
Old Jun 30, 2006 | 09:48 PM
It is located right in front of the fuel tank. You can not hear it at all unless you put your ear right beside it.
Old Jun 30, 2006 | 09:50 PM
nitrousn's Avatar
That sound like a good way to go. Did you but a pump and relocation kit or just a pump?
Old Jun 30, 2006 | 09:52 PM
The kit from Glacier Diesel Performance come with all new lines, fittings, pump, regulators everything.
Old Jun 30, 2006 | 09:54 PM
nitrousn's Avatar
Glacier have a web site? Thanks by the way for the info.
Old Jun 30, 2006 | 09:56 PM
Glacierdieselpower.com
Old Jun 30, 2006 | 10:10 PM
nitrousn's Avatar
Thanks. How long did it take you to install? Did you install the optional pre filter?
Old Jun 30, 2006 | 10:14 PM
1.5 to 2 hours on the install taking it slow and careful. No I did not install the pre filters.
Old Jul 1, 2006 | 08:14 AM
Dodge Demon's Avatar
Running Walbro 392 now for close to 20,000 miles, only way to go. At 20 PSI which is 1/5th of the walbro rated psi,it probably will never wear out, you know if you have a pump that from new that only puts out 20 PSI, it dont take much wear to start losing pressure, theres no reserve,its downhill right from the start, but if you have a pump that puts out 100 PSI but only run it at 20 PSI,its never under load or stress, should last a lifetime,well at least the life of the truck.
Old Jul 1, 2006 | 11:30 AM
CTD01's Avatar
Price
How much is the kit, i just got a new lp, It was like almost $200. The guy at the dealership said this was the last one they had and that next time I would have to put the in the tank one like the third gen conversion. I run 15-18 idle and like 11-12 WOT.
Old Jul 1, 2006 | 01:11 PM
Go to thier website and it will break the prices down for you. Differebt options, different applications.
Old Jul 1, 2006 | 04:42 PM
BobQ's Avatar
What are you using for a pressure regulator? I don't see any regulators on the sight for Glacierdieselpower.com.
I would like to do a replacment for my stock carter pump, but I already have a vulcan kit. I wounder if I can do it?
Bob
