vibration at idle
Old 08-15-2003, 07:19 PM
deje's Avatar
vibration at idle
Does any one else have an abnormal vibration at idle ??? the dealer has had the truck for another week now ,admits there is a vibration. but cannot figure it out.
Old 08-16-2003, 12:54 AM
SuperGewl's Avatar
Re:vibration at idle
First off you didn't say if you have an Auto or Manual Tranny. This info can make a big difference. The auto tranny does have a problem with a slight vibration due to the dip stick being tie wrapped to the heater hose on the passenger side.
Maybe this will help. 8)
Old 08-16-2003, 09:35 AM
spots's Avatar
Tell them to make sure nothing is grounding out on the chassis. If it is a slushbox do you have the vibration in reverse and drive? If only one way you usually have a grounding problem. If both ways you might have a engine mounting problem or imbalance. Sometimes the motor mounts need to me neutralized. HTH
Old 08-16-2003, 12:36 PM
deje's Avatar
its an auto & the vibration is there in gear or out of gear . its from idle to 975 rpms and pretty violent .the entire truck shakes .
Old 08-16-2003, 01:43 PM
spots's Avatar
Has the dealer done an engine power balance? If you have a miss at idle the truck will shake. Mine is a 6spd but quite smooth at idle. Not BMW smooth but I think it is good for an inline 6 oil burner.
Old 08-16-2003, 08:16 PM
dodgedude361's Avatar
IMAdummy, wuts a SLUSHBOX?
Old 08-16-2003, 08:30 PM
spots's Avatar
[quote author=dodgedude361 link=board=20;threadid=18443;start=0#msg173365 date=1061083015]
[/quote]
automatic transmission.
Old 08-29-2003, 05:50 PM
cumminsho2500's Avatar
[quote author=deje link=board=20;threadid=18443;start=0#msg173094 date=1060993183]
[/quote]
ok i do not have anything at idle but when i am coming to a stop slowly it seems the whole dash near the window seems to vibrate... then when i accelerate slowly from a stop i hear it again...do you guys know what this vibe is? :'(
dodgedsl03
01-18-2007 10:08 PM
TurnerBurn
03-06-2006 08:51 PM
89dieselkong
11-23-2005 04:01 AM
Jdub
09-25-2003 04:44 PM
Evildiesel
08-01-2003 11:28 PM
Quick Reply: vibration at idle
