Vibration Damper
Old 11-25-2005, 01:42 PM
nerka992003's Avatar
Question Vibration Damper
I have my vibration damper off and was wondering before I put it back on does it have to go a certain way or can I just put it on and put the bolts back in and torque them? I should have marked it before i took it off (Hindsight)
97 CTD 4x4 5peed K&N
Old 11-25-2005, 03:01 PM
John Faughn's Avatar
look closely at the crankshaft and inside the damper there should be slots for a keyway and that will alow you to put it on in only one way.
Old 11-25-2005, 03:15 PM
G1625S's Avatar
Unless something changed in the 12v block between the 1st and 2nd gen trucks, there shouldn't be a keyway for the balancer...I had mine off twice this last week and never looked twice at how I bolted it back on. Not saying this is right, but I don't think it matters what way you put it back on. Anybody got a service manual handy?
Old 11-25-2005, 07:14 PM
kandgo's Avatar
Bolt it and hit the road,,, Goodluck,,Rick
Old 11-25-2005, 07:42 PM
TxDiesel007's Avatar
All i did was this..
to make sure that it went back on, the times that i have replaced it, is with soapstone (welders chalk) shade one of the screws, and draw a line on the damper... and then you can go ahead and put it back on that way it goes...
its what i did... and it worked..
Tx
Old 11-25-2005, 11:59 PM
Hemi Cat's Avatar
It doesn't hurt to mark it before dissassembly. That is a good habbit to get into. But on the 12 valvers there are no timing marks to align or counter balance weights to time to the crank. It just bolts on. Good luck.
Old 11-29-2005, 04:11 PM
Iron City's Avatar
just bolted mine back on, no issues
Exekiel69
03-30-2012 03:29 PM
CRToney
02-04-2011 06:26 AM
CRToney
02-03-2011 06:30 PM
dodgedsl03
01-18-2007 10:08 PM
tmiller24
01-01-2004 07:19 PM
Quick Reply: Vibration Damper
