Vibration at 70mph
Old 02-14-2010, 01:10 PM
RHC
RHC's Avatar
Vibration at 70mph
As it is cold and snowing, i haven't had a chance to crawl under there and look.
The vibration starts at about 68 mph. If I let off the go pedal the vibration goes away. Does this sound like a rear drive shaft U joint?
Old 02-14-2010, 05:07 PM
mitternocht's Avatar
It might be, you might want to buy a whole new driveshaft assembly any rebuild your existing one when it isn’t so cold and snowy out. (for next time).
Old 02-15-2010, 01:35 AM
BibBubba's Avatar
i just went through that my vibration started at 60 mph or so and after a few weeks it got worse ended up being a rear u joint.
Old 02-17-2010, 07:59 AM
bullhauler05's Avatar
Check carrier bearing??
Old 02-17-2010, 03:48 PM
RHC
RHC's Avatar
No carrier bearing, one piece rear drive shaft.
Old 02-18-2010, 06:06 AM
OIC so you have a short bed then
Old 02-18-2010, 07:08 AM
rbertalotto's Avatar
My truck did the EXACT same thing. I crawled under and everything felt fine. I took it to my buddies shop and he pulled the drive shaft and the rear U-Joint was nothing but red rust dust. There were no rollers in one of the bearing cups.
Replaced the U-Joint and its perfect again. Amazing that I couldn't feel any movement with the drive shaft on the truck.
Old 02-18-2010, 02:51 PM
Dave04600's Avatar
my vibe started at 50, needed new ujoints here too.
Old 02-20-2010, 08:03 AM
RHC
RHC's Avatar
Couldn't see signs of dust around the u joint caps. So it's been about 50-55K miles since the tires have been rotated and balanced. but they are worn even across, still look good. ( BF Goodrich original factory tires with 73000 miles on them.) Had them rotated and balance and the vibration went away.
Still have a drone sound at about the same speed that pulsates at cruise control speed.
msatow
190
06-18-2014 06:37 PM
Dave04600
18
08-07-2012 10:12 PM
rbox
17
05-23-2008 07:57 AM
CCOUGHRAN1
04-27-2007 08:16 AM
jthorpe
27
09-22-2004 06:04 PM
Quick Reply: Vibration at 70mph
