VE pump ?
Old May 4, 2010 | 09:04 PM
w.tx iceman's Avatar
VE pump ?
200 k on a ve pump that has an intermittent leak,is it worth doing the reseal or should i get a rebuilt one?
Truck runs and starts great although i don't have anything to compare it to,(first 1st gen I have been around.)
TIA
Old May 4, 2010 | 11:18 PM
93flatbed's Avatar
I say reseal.
It should start on half to 1 full revolution.
And if stock they are a little combersome of a truck, but still move down the road. If that makes and since?
Old May 4, 2010 | 11:37 PM
jimbo486's Avatar
where's the leak coming from?
Old May 5, 2010 | 12:50 PM
Benjamin b2's Avatar
i say rebuild it, its way cheaper now, then it is later
Old May 5, 2010 | 08:10 PM
Can't be sure but it looks like top, in front of the throttle shaft, one of those you can,t get without pulling the pump. I have changed a vp-44 before but really not looking forward to pulling this one.
But is hasn't leaked since the temp has come up,runs good ,and will bump right off in 1/2 second
Old May 5, 2010 | 08:17 PM
Twisted Inc.'s Avatar
there basically the same as the vp44 to remove....just make sure you lock the pump at TDC before you remove it....
Old May 5, 2010 | 08:53 PM
Thanks for the help guys
Got a new place to hang out on here now
Old May 5, 2010 | 09:34 PM
93flatbed's Avatar
Before long you are gonna want to trade your truck with your sons. LOL
Old May 6, 2010 | 04:40 AM
w250_93's Avatar
If it's leaking out of the gov shaft make sure u mark it good so u can put it back in the right spot or it could run away.
Old May 6, 2010 | 12:40 PM
apwatson50's Avatar
A rebuild isn't necessarily any better than resealing yours. And the gov shaft isn't that picky on the adjustment.
When you buy a rebuild they don't necessarily replace hard parts, unless they're worn out. If the head/rotor are in good shape there is really nothing else that wears out. As long as its had clean fuel with no water in it.
Old May 6, 2010 | 02:42 PM
jimbo486's Avatar
yup! the "rebuild" kit only contains the necessary seals to be replaced. should be called a reseal kit. why they call it a rebuild kit, who knows. hard parts will cost you some $$$ too!
powerwagon440
May 25, 2003 02:31 PM
Puke
May 22, 2003 12:18 AM
amartinson
0
May 4, 2003 01:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
