upgrade options- chip, downloader, programmer?
Old 10-09-2007, 01:22 PM
paroxysym's Avatar
so my goal, is to have around 400-450 rwhp. im hoping to get there by next spring. im uncertian though on what direction i should go as far as chips/programmers go. i have thought about going with the smarty, or the predator/puck option. what else is out there? i currently have the quad xzt, and its a nice little chip. the amount of timing rattle/injector noise is alittle irritating so im looking for something that doesnt do that as much.
so what are my options? help me reach my goal. i def plan on going with a georend tc/vb, a mag-hytec deep pan, maybe a flexplate or something else to help the tranny. i wasnt sure what i should do with fueling as far as aftermarket lift pumps go. what do you think there? thanks for the help and insight guys, appreciate it.
Old 10-09-2007, 01:32 PM
P.J
P.J's Avatar
Smarty has been fun (for me). It has a pretty bad rattle to it on the timing added numbers too though. If it were me (which it will be by summer time) I would look into a Glacier Diesel (Walbro) kit. I have read many, many success stories with that set up.
Smarty (with the trans work) will get you past the 400 mark no problem.
Old 10-09-2007, 01:38 PM
Mark1si's Avatar
Smarty TST is a great stack.!!
Old 10-09-2007, 01:40 PM
DTR 1st Sergeant
soulezoo's Avatar
You can get about 475+ with smarty alone. Don't like timing?? Just use the even numbered sw's.
Old 10-09-2007, 01:52 PM
P.J
P.J's Avatar
I have been conservatively figuring I was in the 440-460 range. Have yet to get it on the rollers though...
Old 10-09-2007, 03:16 PM
rufushusky's Avatar
Always good to practice conservatism...FASB likes it. Anyways at 400-450rwhp you are pushing what your stock tranny can handle. I would do a Valve body and torque converter upgrade to help should the load and so long as you are not doing any boosted launches you should be ok. Then a TST with a pressure box and a descent fuel system and you should have that number no problem. As far as fuel systems go a Glacier diesel pump is nice and FASS is pretty good too. Personally since I am a poor college kid I am gonna run a Carter P4600HP or P4601HP lift pump inline with my stocker with a big line kit
Vinceg99
11-21-2007 12:34 PM
toupee
06-07-2007 08:54 AM
UnrulyNFS
13
03-30-2007 07:12 AM
BossHogg
09-07-2006 12:36 AM
04ctd
103
01-29-2006 08:11 PM
Quick Reply: upgrade options- chip, downloader, programmer?
