U-joints??
Old 07-07-2007, 01:01 PM
swhite832's Avatar
U-joints??
I let a buddy borrow my W350 to pull a heavy load (16ft. trailer w/lumber). When I drove it last it had a shudder at about 70-75mph. Seems like a u- joint issue. Is there any way to diagnose for sure without throwing parts at it? Could it be something other than a u-joint?
Thanks in advance.
sTw
Old 07-07-2007, 02:10 PM
MoparMarv's Avatar
Go under and look at them and see if any have more slack in them than the others. Maybe pump in a little grease and see if that helps.
Old 07-07-2007, 05:30 PM
dieselJon's Avatar
Drive it around for a while then feel them. If they are burning to the touch, replace them. Mine I just did. Had a shudder between 20-35, did the above method. I started at the rear and moved forward. The rear shoulda been glowing red, it was that hot. The second was not much better. The front one felt like ice compared to the rear 2. When I changed them out, I had 2 caps with dust in them in the rear one and the middle one had only one that grenaded. The biggest roller bearing part was probably 1/32" big
HTH
Jon
kprc51
06-14-2007 06:27 AM
njmaier
15
07-26-2006 07:43 AM
getblown5.9
05-02-2006 10:01 PM
Seeder
02-15-2006 08:15 PM
Dynocon
03-05-2005 06:24 PM
Quick Reply: U-joints??
