U-Joints, looking for beefy ones
Old 03-28-2007, 12:11 PM
nfsommer's Avatar
Well since im having my axles ripped apart and re-done i'd like to address the u-joints also, all of them, what company has the best u-joints that could handle some punishment?
Old 03-28-2007, 03:41 PM
nfsommer's Avatar
is there something wrong with the webiste?
Old 03-28-2007, 03:44 PM
annabelle's Avatar
NAPA or Moog.
Old 03-28-2007, 04:01 PM
nfsommer's Avatar
im not looking for OEM u-joints, i need somethin way stronger with 42's and 400 hp...?
Old 03-28-2007, 04:36 PM
nfsommer's Avatar
I just looked into precision u-joints and found this on another thread
I read a guy with a 600 hp truck who did sled pulling was ok with his u-joints i just need verification these are right for an auto truck?
Rear driveshaft 2 Piece precision (takes 3) Precision #295
Front driveshaft Cardan H joint (takes 2) Precision #232
Front driveshaft @ front axle (takes 1) Precision #235
Front Axle U joints LEFT AND RIGHT (takes 2) #464
Old 03-28-2007, 04:59 PM
PourinDiesel's Avatar
Nick,
Some of those part numbers have changed since I wrote that a long while back.
Best thing to do is just buy the complete front driveshaft as an assembly.
Also go to www.rockauto.com and find the correct u joint for your truck.
Old 03-28-2007, 05:06 PM
ptgarcia's Avatar
There are several companies that make heavy duty u-joints, but I don't know what fits our trucks. You can check out Dana Spicer or Ox U-Joints and see if something will bolt up. Good luck and let us know what you find.
Old 03-28-2007, 05:35 PM
Little03's Avatar
Try C.T.M, I believe is the company name they chriogenitically Freeze axle shafts, U-joints and so on. really tough stuff.
Old 03-28-2007, 06:01 PM
nfsommer's Avatar
ctm only makes for dana 44 and 60..
Dana Spicer or Ox U-Joints = both not out yet
and on rock auto there are many choices, i really have no idea what to use cuz many of them say premium or high strength??
Old 03-28-2007, 06:49 PM
Nick for what you are doing the Precisions from Napa or Rock auto are more than enough.
Old 03-28-2007, 06:54 PM
scottsjeeprolet's Avatar
My vote is for Dana Spicer. I only run them, the Ox and CTM are for off road use only. They are not designed for constant use. Unless you convert the front end to manual hubs.
then again i have been known to be wrong.
Old 03-28-2007, 07:01 PM
nfsommer's Avatar
well guys i do have the dynatrac hub conversion in front..
Old 03-28-2007, 07:06 PM
nfsommer's Avatar
even with the 42's?
I do plan on mudding with this truck
Old 03-28-2007, 07:07 PM
Crimedog's Avatar
Aren't the 03+ axles AAM, so Spicer wouldn't make anything to fit them, correct?
Old 03-28-2007, 07:25 PM
nfsommer's Avatar
yes spicer doesnt have em yet , and from what i was told on the phone today they wont for a while..
Quick Reply: U-Joints, looking for beefy ones
