Twin Turbo Drain Tubes
Old 01-13-2010, 04:41 PM
sleeperman's Avatar
I making my own twin turbo set up and was wondering would the factory drain would work if I weld a Y on to it and have both turbos drain into the factory oil drain?
Old 01-13-2010, 04:50 PM
"sgreen3" just did this, he said it works good
https://www.dieseltruckresource.com/...d-t260876.html
Old 01-14-2010, 12:59 PM
stackx2's Avatar
on my 1st set of twins i did this and it worked fine. you just have to make sure that you have enough slope on your drain line so the oil doesnt back up. on my 2nd set of twins i built, my bottom turbo was to low to t into the existing line so i had to tap into my oil pan which seems to be working good so far. it all depends on how you are going to biuld your setup to where you have to run your drain line.
Old 01-14-2010, 08:24 PM
sleeperman's Avatar
i plan on mounting my twins over under and after a while of the hx35 hx55 set up i hope to go to a ht3b under a 60mm hx35 mounted in the same way.Im hopeing for 400 to 450hp range with some 6x16.
Old 01-15-2010, 02:23 AM
stackx2's Avatar
i would just stick with the hx 55 i love it. it is perfect for the hp these little ol ve pumps put out. im makeing 407hp and my egts never got over 800 on the dyno and towing a 25' gooseneck with a backhoe they never get past 1100*. i honestly cant see the need to any bigger with a bottom turbo.
Old 01-15-2010, 06:24 AM
sgreen3's Avatar
Yea I just put a "Y" fitting in the drain hose, just install it as low as possible, I have no trouble with it!
Old 01-15-2010, 09:14 PM
sleeperman's Avatar
why are you and stackx2 only using pods and not going with some custom injectors that make better power and get better milage and make less heat?i had pods and sold them to buy my studs and im going to something better.
fade94
02-07-2011 12:12 PM
1974d2004x4
13
10-17-2007 07:47 AM
BigBlackBeast05
07-24-2005 09:47 PM
1ST GEN.
02-03-2005 12:00 AM
AZGEARPRO
11-03-2004 07:53 PM
Quick Reply: Twin Turbo Drain Tubes
