turning "the pump" up
Old Aug 30, 2007 | 12:31 AM
BigErksG2's Avatar
anyone know how to turn the fuel pump up on a 12 valve? about how long does it take?
Old Aug 30, 2007 | 06:36 AM
lonewolf42262's Avatar
Depends on the lvl of turned up you seeking, There are afc mods, that can be done, diff fuel plate profile #10, #100 #0, delivery valves (laser cut 181's, 191's). You can have the fuel plate installed and adjusted in under a hour. DV's take about a hour with a DV socket. Govenor spring kit takes about a hour for the 3GSK, 4 and 5 take longer due to valvespring installation. I am not exactly sure what you meant by turned up. Theres quite a few adjustments that can be made. A fuel plate and adjustment will get you a large increase in power, and govenor spring kit makes driving alot of fun.
Old Aug 30, 2007 | 02:29 PM
BigErksG2's Avatar
the pump
those are the mods that i knew of but a new friend mentioned to me turning up the pump and it wasnt a fuel plate, gsk or delivery valve mod. i guess he was talking out of the wrong orphus. thanks for clearing it up.
Old Aug 30, 2007 | 03:14 PM
Ramdriver15's Avatar
search for post " all free 12v mods" You will find all you need to know, or just PM me. I love p-pumps!!!
Old Aug 30, 2007 | 04:11 PM
some people refer to turnin the AFC screw as turning the pump up also. But this just increases or decreases low end fuel
Old Aug 30, 2007 | 06:22 PM
Paul Winey's Avatar
BigErksG2:
Your friend wasn't talking out the wrong orifice sorry to say.
He meant one of two things. On first generations you can turn up the screw to increase fueling. On 12V second generations you have to take the injection pump off and have it recalibrated on a bench stand. This will give you even more fuel above and beyond what the other mods will do. It is worth the time and trouble. Pump takes about 30 - 45 minutes to take off, about an hour of bench time and 45 - 60 to reinstall and recheck timing. Easy to do, easier with a 15mm swivel head socket and long extension. The whole write up is in the Haynes manual. Also makes it very easy to adjust the govenor arm with the pump off.
Now go apologize to your friend, say you're sorry and make nice.
305motorsgt
Apr 27, 2014 08:17 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Gutterslug
Aug 16, 2007 04:46 PM
SilverSootXpres
Apr 17, 2007 11:13 AM
Sux 2B urTurbo
23
Aug 14, 2004 11:56 PM
