turbo upgrade
turbo upgrade
Whats the ideal turbo upgrade.. Ive already done a denny T and slightly bigger 40+ injectors. I was thinking of a 16 exhaust housing. And ??? not sure on the compressor size to use.
Thanks Johnny
Thanks Johnny
This is a service bed truck... The truck runs really good. Very clean. pressure tested and seals are tight.
I have extra tool boxes on it and drain machines. (fairly heavy load but not too heavy) I'll tow a trailer occasionally. Mostly driving the Interstates Around Nashville Tn. hitting traffic only a few times a week.
I want good acceleration yet optimal Fuel mileage. I like to hear the turbo some. but dont care for a ton of smoke out the back.
I wanted to up my boost to save fuel and add power. The truck is running strong. But i want a clean exhaust and just a little more power. 17mpg now I want to get closer to 20mpg ... the last one i had like this got 21... bonestock. Ill be replacing the exhaust as well.
I will again recommend the he351cw. Works great. I paid 350CAD for a used one, installed a rebuild kit ($100) for piece of mind but don't think it needed it. You will need a different exhaust flange on the downpipe but you can get that with the new exhaust. Currently i am getting 28psi boost with stock pump. You can here the turbo just enough and i have no smoke at all, at any time. Hardest part of install is getting a piece of pipe that will connect the compressor outlet to the IC (if you have one). What year of truck?
[QUOTE=BILTIT;3099559]I will again recommend the he351cw. Works great. I paid 350CAD for a used one, installed a rebuild kit ($100) for piece of mind but don't think it needed it. You will need a different exhaust flange on the downpipe but you can get that with the new exhaust. Currently i am getting 28psi boost with stock pump. You can here the turbo just enough and i have no smoke at all, at any time. Hardest part of install is getting a piece of pipe that will connect the compressor outlet to the IC (if you have one). What year of truck?
Its a 91.5 intercooled I would love to set mine up like this... where can i find a deal like that on the used turbo??. And the waste gate? How did you set that up?
[QUOTE=johnny08;3099566]
I found it in the local ads. Wastegate is tack-welded shut, non-functioning.
Here is the 60 you should get if not changing turbos:
http://www.gillettdiesel.com/H1upgra...wheel60mm.aspx
And the exhaust housing you are looking for:
http://www.gillettdiesel.com/16cm2no...housing-1.aspx
As you can see, you can upgrade to a 351cw for not much more than these two upgrades alone.
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
12valve
Feb 22, 2007 09:07 PM
