Turbo upgrade ?????
Based on my current mods what turbo upgrade do any of you recommend, yes I searched but nothing with my setup poped up. I do plan on upgrading injectors and tranny (when it breaks) but I am looking at the turbo 1st?? what do you all think???
If you go with a bigger set of injectors, I'd go with a set of 150hp stix. You cant go wrong with F1 Mach 4's or DDP's 150hp injectors. As for the turbo, either an Industrial Injection SPS 62/14, or HTT 62/14 if you go with the bigger sticks. However, at that level, I would definately consider head studs and either o-rings or a cometic gasket.
I have a simular truck, with the mach 4's, which I might add are good enough to start whole other thread about.
I was looking for around 500-550hp, and do some towing. I went with a HTT SS 64/71/13.
Spool up is just a tiny bit lagy, but I also am NOT running any tuning until I can get a Quad A. I did have a Smarty and a 140hp box on it for a long while and it spooled great. I could clean up every bit of smoke.
The 64 is more than likly bigger than most run, but I don't want smoke.
A 62 would be perfect. I went with HTT, because of the SS and 13 snail. There are several good 62's on the market from many companys.
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
12valve
Feb 22, 2007 09:07 PM
