turbo
Old Jul 25, 2005 | 01:53 PM
smokNjoe's Avatar
Question turbo
ok this is of the topic of diesels but me and a friend are building a dune buggie and we have a turbo for it but the problem is the oil return is in the up position when we mount it were we want it would it be a prob if it was like that or does it have to be pointing down also can you rotate it in the housing any info would be a ton of help
thanks joe
Old Jul 25, 2005 | 03:05 PM
bgilbert's Avatar
Depending on what turbo it is, if its like a h1c or hx35, you can just separate the two housings- compressor and exhaust, install them back with the oil drain down. Then you'll probly have to 'clock' the compressor housing. Some c housings will have a big snap ring holding it in place or a big clamp, loosen it and what I did with a hx40 just used a rubber mallet and beat on it til I got it rotated where I wanted it. BTW I had the same problem with my hx40, oil supply down, oil drain up and compressor outlet facing the wrong direction. Separated the two housings, reinstalled, the clocked the c housing.
Old Jul 25, 2005 | 03:22 PM
What Bill said is true, pretty much every turbo out there can be reclocked easily. The oil drain MUST be pointed down, and the return line has to be at least 5/8" ID or oil will back up and leak out the shaft seals. Also, the crankcase or oil tank must be well ventilated, any pressure will cause the same problem.
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
