Turbo/ injector combo- what's best?
Old 08-10-2007, 05:11 PM
CTD600's Avatar
Just upgraded my tranny on my 2001 and now looking to add power to my daily driver. Looking for advise on the best set up for mainly hot roding 1/4 mile. I will be towing very light or not at all. I have an Edge comp and FASS.
Thanks,
Old 08-10-2007, 05:44 PM
Mike D's Avatar
Injectors.
Old 08-10-2007, 09:25 PM
CTD600's Avatar
I was accually trying to find out what turbo and injectors work well together with the comp box and FASS that I already have. I'm looking at injectors in the 150 hp range. This truck is my daily driver so it needs to stay streetable. Just trying to get some ideas.
Old 08-10-2007, 09:28 PM
dieselfan's Avatar
mach 4's or 4.5's or ddp stage 4's are excellent choices and either a HTT or Phatshaft 62mm turbo would be perfect.IMO
Old 08-10-2007, 09:33 PM
The Guru
Mike Holmen's Avatar
If your building a hot rod truck for around town driving and towing go twins. A setup with the 40/3b works well or the 62/14 S400 is another hot set-up. Mach 6 would be too hot for towing in the hills.
Old 08-10-2007, 11:30 PM
MSquare's Avatar
I have run multiple configurations over the last few years. I just changed and think my current set up is exactly what I've been looking for.
I've had a Smarty, Comp, EZ, TST PM3, DD2's, DDP5+. The only thing I didn't run with my HTT 64/14 is the EZ.
What I'm running now is a Drag Comp, DDP 4's and the 64/14. It is a dream to drive! No more touchy go pedal, less smoke during daily driving and on the fly adjustability.
Old 08-11-2007, 08:36 AM
CTD600's Avatar
MSquare-
Your setup is about what I'm looking for. Do you have much turbo lag with that set up. Any 1/4 miles runs?
Old 08-11-2007, 12:52 PM
MSquare's Avatar
Very little lag, if any. I'm still in the "getting used to it" stage. I went from the Smarty and DDP5+, to the DC and DDP4's.
I haven't run any 1/4's and I'm not planning on it. But it moves very well! I'm trying to schedule a dyno session this next week, I'll post and pm the numbers when I get them.
I am extremely happy with this set up. Far and away the best that I have had.
Old 08-11-2007, 03:03 PM
1BAD4X4's Avatar
Did the Smarty and DDP5+ smoke too much for your liking?
Old 08-12-2007, 01:19 AM
MSquare's Avatar
No, the smoke was easily controlled. The biggest issues for me were with the Smarty's lack of adjustability on the fly and the touchy throttle. DDP injectors are great.
Old 08-12-2007, 08:57 AM
The Guru
Which smarty setting you using? I found that using level 5 works just about as good as stock but with the some of the catcher. 7 is nice to, more smoke. How much smoke does the ddp5+ make? I have a set of ddp 62litre pre minute injector are they the same as your's? I just get a bit of smoke on spool-up. I can pull around the 70psi mark and just have a bit of haze. At sea level the smoke would be gone and nice daily driver.
Old 08-12-2007, 10:21 PM
MSquare's Avatar
Mike-
I was running on level 7 for most of the time, 5 during the winter and the last month or so, on 3.
The DDP 5+ was a 48 lpm. The big difference is your twins versus my big single. With my old set up and twins, I probably would have had to lug the motor to produce much smoke. With the single I could black out tailgaters with ease!
With my turbo (no twins in the future), the 40 lpm sticks I have now and the DC are a perfect combo.
62's? OMG! Thats alot of fuel!
Old 08-12-2007, 10:32 PM
The Guru
still not enough... I need a bigger pump. Next year, I want ddp worked injection pump. Big HP!!! and a little biny bitty bit smokey.
jmd4993
07-15-2013 11:02 AM
TorqueJunkie
18
02-02-2007 03:01 AM
Txsmoke
11-26-2005 02:34 PM
BigBlock
01-17-2003 10:58 AM
Quick Reply: Turbo/ injector combo- what's best?
