Tuff Country sucks?
Ok. TuffCountry sucks, at least a little.
I was coming home and at one crossroad which I was coming a little faster than normally, I felt/heard big bang and my steering went all crazy.
Can you believe this, that sway bar drop brackets two bolts snapped!
Allmost wrecked my truck. Well... Maybe I'll survive if I change stronger bolts there...
But, be aware...
But, be aware...
Nope it wasn't right after that.
I have driven over two tanks and several tight turns after playing around with the tractors front end loader.
Blah... now the track bar drop blocks supporting bracket broked... Well just welded it together and little strengthened it... What a pain a one block could be. But I hope it's ok for now.
And I do not want to take the stabilizers off...
I never trusted those things, I went right for the solid steel 03 conversion with the 3" lift and standard 03 trac bar. When I went above 2" though I had to get the adjustable bar. I've hit quite a few hard bumps and rolls with no ill effects yet. Also like 97' CTD said most of those come with cheap grade bolts 2/5 for the stress thats on them deffintly go grade 8.
lvmknsmoke..
03-25-2009 05:57 AM
kry226
01-29-2004 07:09 PM
