Truck is missing HELP!!!!!!!!!!!!!!!
Old 10-16-2005, 10:27 AM
crittergetter's Avatar
i just got this truck three months ago its a 01 5 speed 4x4 with 120000 on it. it started missing about a week ago at idle it sames to run fine down the road with all of its power it does not do it all the time. it does smoke some but it looks to be black smoke. it does it with the ac on are off. i replaced all of the filters when i got it. the fuel filter was clean the air was dirty but all are new know. it is stock for as i know with a straight pipe. i tested the fuel presure and it was 12 at idle and 8 at wot. is my pump going are what the heck could it be. i would like to try to fix it with out a trip to the steeler. please help
Old 10-16-2005, 10:35 AM
P.J
P.J's Avatar
Any Codes? Pressures sound fine.
Old 10-16-2005, 10:36 AM
how do i find codes
Old 10-16-2005, 10:43 AM
P.J
P.J's Avatar
It's in the "tech facts" section. Key on, off, on, off, on (on, not start). Codes, if any will read in odometer and follow by P Done. Try it, see if you see 0216.
Old 10-16-2005, 11:26 AM
no codes, i started it just now cold (over night) it idled fine. drove it down the road about 2 miles and its missing.
Old 10-16-2005, 11:37 AM
P.J
P.J's Avatar
Huh.
Dunno. No other symptoms? Recent changes?
Old 10-16-2005, 05:10 PM
phox_mulder's Avatar
That's what mine was doing when the VP44 was dying.
Idled like crap every other start or so, but ran fine at speed, then would miss again when engine speed got down below 1K.
Never got any codes, and I'm still running the original lift pump.
phox
Old 10-16-2005, 05:20 PM
DustyRock's Avatar
From the title of your post I thought your truck was stolen! Better to have to replace the VP44 than the truck.
Old 10-16-2005, 05:33 PM
isissound's Avatar
i got the same notion
Old 10-16-2005, 10:26 PM
so ever one thinks its the ip how much is this going to be and how hard is it to replace can i do it my self. is there any better pump to get over stock. i was going to get some stage two injectors and a edge race pro i guess thats on hold
Old 10-17-2005, 12:10 AM
piperca's Avatar
Mine has been missing intermittently for the last couple of months. I, too, am trying to troubleshoot it, but the last thing I'm going to look at is the IP. Mine was replaced about 30k ago. I'm looking long and hard at injectors. I don't have any codes either. I'm sure there's a multitude of things to look at before you start spending the money for your mods.
Old 10-17-2005, 04:53 AM
tmleadr03's Avatar
Hey guys, maybe your looking too deep by going to the VP44 so soon. Try going back to basics first. What does this engine need to run? Air, fuel and compression. If it doesnt get any of those it can miss-fire.
So possibilities are: Air, clogged intake (not that likly); Fuel, vp44 missing, clogged injector, damaged clogged high pressure line, crimped low pressure line (this can give a false good reading or a slightly high reading on your fuel pressure, you can double check by doing the volume test). The only thing this problems would probably affect all of the engine. Does this sound like its one cyclinder? If so it might be sticking valve/s (no compression in a cyclinder) or sticking injector (no fuel/not enough fuel). Before you go for the MAJOR fix, try a decent injector cleaner. That dont work, try a compression test (this is a bit more in depth tech work).
Some times it is a bad thing our engines dont make vacuum, so much easier to diagnose with vacuum.
Old 10-17-2005, 06:47 AM
tmleadr03's Avatar
Ok, only thing on all data that I can find on compression is a 16.5:1 ratio. Perhaps thats not the best way to diagnose the missfireing piston.
Old 10-18-2005, 01:24 AM
AAmeeting's Avatar
You may just have a bad injector. The tolerances inside the tip are quite small. I have a set right now that was claimed to be missfiring, and upon disassembly the pintle was siezed in one of the nozzels. Just throwin it out there..............
Old 10-18-2005, 10:43 AM
piperca's Avatar
As I said before, mine has been missing for a while and yesterday it threw a code ... P0122-TPS circuit low. I think I'm going to replace the map sensor too, when I do the TPS. Hope this helps!
Quick Reply: Truck is missing HELP!!!!!!!!!!!!!!!
