Trouble relocating egt probe
Old Oct 3, 2012 | 10:35 PM
440727's Avatar
The previous owner had a RW products egt gauge installed in the turbo down pipe. The probe/fitting is 1/2 in diameter with a 5/16 thread. I drilled the original cast iron manifold out with a 27/32 drill bit. I tried tapping the manifold and its only tapping on part of the hole. Meaning if looking from towards the firewall its got threads from roughly 8 o'clock to 3 o'clock. I am moving from Ohio to Arkansas this Friday and need this truck.
Thanks guys !
Old Oct 4, 2012 | 12:20 PM
infidel's Avatar
It sounds like you're using the wrong size tap.
For a 27/32 drill it should be a 1/4" NPT tap.
Far as I know pyro probes are either 1/8" or 1/4" NPT, nothing else.
tomd
Dec 12, 2006 10:56 PM
KATOOM
23
Jul 28, 2004 02:17 PM
N.Johnson
Jun 24, 2004 09:23 AM
Rattlerattle
Jun 30, 2003 07:19 AM
