Tranny question
Tranny question
I have an '89 2wd with a 727 and a 3.07 rear end. Should I get a GV OD or replace the 727 with a 47RH? Trying for less rpm at freeway speed. The locking convrter would be nice too...
From: Smith Valley, NV (sometimes Redwood City, CA)
You already have a very high rear end. Are you sure you want to go higher still? I think the 46RH was the tranny in my '93. It had the OD and might be the tranny for you. I had the 3:54 rear end in mine and I put oversized tires on it. The performance was noticably less with just that little bit of ratio change. If you get too high the performance will be very sluggish and won't help mileage a bit.
John
John
I respectfully disagree. Adding OD and keeping those gears is fine and IMO a great idea. The diesel torque will overcome the gearing like a gasser would not. Milage will likely increase a bit, especially if you added lockup converter.
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
