Tranny fluid
Old 09-12-2005, 09:12 AM
Big Deezul's Avatar
Tranny fluid
What is the difference between the chrysler tranny fluid atf+4 and mercron/dext3?
Old 09-12-2005, 02:48 PM
Mike D's Avatar
Not sure, but I'm running Mer/Dex in mine, along with some LubeGuard.
Old 09-13-2005, 01:26 PM
Big Deezul's Avatar
so you dont use the atf+3 that chrysler recomends?
Also off topic here...how in the hell do you get you truck to smoke like that. I have the same mods as you and mine is usually just a puff at take off.
Old 09-13-2005, 01:32 PM
Mike D's Avatar
Nope, I've been running the Merc/Dec without any problems. I caught on the the idea from Bill K. at DTT.
Without seeing your sig. You have a Mad ECM?
Old 09-13-2005, 01:45 PM
HiJenks's Avatar
I just got back from the Mopar shop, went to get some liquid gold they call "limited slip additive" and I ask that question. The parts clerk said that it was a special formulation for 2000 and up trannys, that Mercon/Dextron 3 was OK for all up to 2000.
Why doesn't anyone make the ATF+4 if it has been in since 2000?
Old 09-13-2005, 06:07 PM
Big Deezul's Avatar
what is Bill's theory behind it?
No...I dont have the mad ecm..I just saw it in your sig
Old 09-13-2005, 06:30 PM
phox_mulder's Avatar
Chrysler held the patent and didn't license anyone else to make it.
I heard that just recently, they started allowing others to make it.
Hopefully the price comes down as a result.
phox
Old 09-14-2005, 08:03 AM
Mike D's Avatar
I don't know if there is a theory to be honest. I would hate to speak for him, but I think he recommends Mer/Dex to be used in his DTT trannys and to change the fluid every 10,000. Speaking from personal experience, since using Mer/Dex the trans does shift better. I don't have a temp gauge so I wouldn't be able to tell if it runs any cooler than with atf+3.
Old 09-15-2005, 07:34 AM
Big Deezul's Avatar
Thanks for the info.....I think I need a mad ecm that avatar looks awesome
Common
06-09-2008 12:16 PM
Tommy93w350
06-26-2007 04:42 PM
2500
10-02-2006 09:14 PM
icrider
09-27-2006 03:10 PM
Quick Reply: Tranny fluid
