trailer brake wiring
Old 04-17-2008, 10:35 AM
smokeyram's Avatar
Twice now I have had the harness fry on me. Both times i noticed when the running lights were on, switch off. The plug receiver itself is corroding and shorting itself, backfeeding the running lights.
Where am I going wrong. I have a drawtite "activator" controller which has been acting odd also. the light on it is on sometimes when im not even touching the brakes. indicating its sending a signal to the brake wire.
For the life of me I cannot figure it out, and its getting tougher and tougher to find my way through all the wiring anyhow.
Am I best off just getting a new controller and wiring and starting from scratch?
Old 04-17-2008, 11:01 AM
roughstock's Avatar
On most controllers, there should be a light "on", that indicates that the trailer is connected and brakes are connected, it will change color when brakes are pressed. Does your truck have factory trailer/tow harness? Check for frays where it rubs frame rail, in the area where you spare tire is near frame on drivers side.
Ive found that 90% of the time, the problem with trailer/truck wiring is in the plugs, replace both trailer and truck plugs and try it again.
Old 04-17-2008, 06:14 PM
carl48's Avatar
see if you can find a tube of dielectric grease and especially the truck plug needs it and then wrap the back with rubber tape and then electrical tape
Old 04-18-2008, 01:59 PM
smokeyram's Avatar
ive done both things, dialectric in the plug, and checked for bad wires and shorts. when crawling under a truck with 175000 on it, im thinking time would be better spent putting in a new controller and harness wiring.
Old 04-20-2008, 08:12 AM
chaikwa's Avatar
I would tend to agree with you, but before you go thru all that, make sure that the trailer plugs, both on the truck and trailer, are receiving a good ground. Bad grounds cause more problems than any amount of time and money can cure!
chaikwa.
stumpjumper
09-20-2007 06:57 PM
robert97dodge
07-18-2007 08:36 PM
DieselSmith
05-14-2007 09:25 PM
RAF
03-16-2007 05:10 PM
charcoal600
04-30-2005 02:34 PM
Quick Reply: trailer brake wiring
