Trac bar and steering ???'s
Old Jan 28, 2003 | 11:00 AM
perk's Avatar
Trac Bar:<br>I had my pickup in at Les Scwab, and they said I need a new trac bar and a steering box. I have looked at Luke's Link and the DT trac bar, which one would be better? Truck has stock suspension and will for probably for another seven years. <br><br>Steering Box:<br>Anyone know of a box that is WAY better than stock? we will probably have the truck for at least seven years, and I don't want to do this every 120k.<br><br>Thanks in advance for your help.<br>
Old Jan 28, 2003 | 11:10 AM
DF5152's Avatar
Re:Trac bar and steering ???'s
I have used the DT trac bar in the past on my 98 gasser was an easy install and worked well the Heim joint does wear out. There is an after market company that make steering boxes and matched pumps the name and URl escape me now but as soon as i sign off it will come to me. <br>Dan
Old Jan 28, 2003 | 12:06 PM
Ruralmedic's Avatar
Don't know about the trac bars you've mentioned, I have the Moog on mine, and thus far OK.<br><br>There is a thread somewhere on this site about a fix for loose steering. It's made by a fellow in Canada. A bracket containing a pillow block bearing is added to the pitman arm, giving it support and eliminating play. I think it's about $125 US for it. Sounds like it fixes our &quot;Wanderers.&quot;
Old Jan 29, 2003 | 02:13 AM
Dieseldude4x4's Avatar
Installed Lukes Link on mine. Tightened the front end right up and is adjustable as it wears.
Old Jan 29, 2003 | 09:06 PM
perk's Avatar
I think that we will try the Luke's Link. We are still looking at steering boxes.
Old Jan 29, 2003 | 10:19 PM
perk's Avatar
Shire,<br>Thanks for the info, I guess we are in the same plight. What is the JBC kit you list in your sig?
Old Jan 30, 2003 | 09:35 PM
perk's Avatar
Scott,<br><br>I had an idea earlier today about using a box off of a 3rd gen Dodge. It is supposed to be a great box, and it might be easier to incorperate. I haven't looked at any of the new ones, and don't know if they are even remotely compatible.<br><br>I do not like the idea of the slave cylinder steering. Ford used that when they first came out with power steering on the '73s. I have a friend with one, and it leaks like a sieve, and isn't very effective. Aside from all that, I am not a rock hound, so that doesn't interest me either.<br><br>Thanks again for your help.
Old Feb 1, 2003 | 04:01 PM
rtm038's Avatar
DT all th way!<br><br>Ryan
89dieselkong
Feb 12, 2011 10:06 PM
Racing_Joe66
Apr 7, 2010 06:05 PM
Buz
May 28, 2007 07:01 PM
Diesel Demon
Jan 17, 2006 08:59 AM
