tq managment
Old 10-12-2006, 10:35 PM
jtskir222's Avatar
tq managment
what is tq managment on the triple dog ? does it slow you down or make it faster?
whats the best settings for the triple dog with outlook?
Old 10-12-2006, 11:07 PM
acook's Avatar
If you have a stock, or close to stock transmission itll slow you down into the breakdown lane. The tq managment comes on the trucks from the factory, its DC solution to their junk trannies, it cuts power untill you get going.
Old 10-13-2006, 05:41 AM
jtskir222's Avatar
tq
i have an 05 with the triple dog set up and the TQ managment i am speaking of is the option you get when you use the new program from bully dog??
Old 10-13-2006, 08:14 AM
Smokeman's Avatar
Right..and Bullydog lets you take the torque management off. What acook is telling you is don't do it if your transmission is stock as it is hard on them. If torque management is removed you have much stronger bottom end power but your drive train may not handle it for long.
Old 10-13-2006, 11:05 AM
Luken's Avatar
Dont take the tq management off if you have a stock tranny. It will break....
Old 10-13-2006, 03:31 PM
HeberRam's Avatar
Wink torque management BDDL
Like Luken said, don't take the torque Management off. I would also not take it off, even if you have a good trans. The only exception, is when you are at the track. What it does when you take it off is, it stops the engine from de-fueling
between shifts, and is hard on trannies. Normal driving and road rages, you should leave it on. IMHO. The same goes for the low end throttle/torque option
and best used when racing at track.
Old 10-13-2006, 03:36 PM
jtskir222's Avatar
I'm Kind Of Lost... I Just Set It Back To Stock Then Re Up The Bully And Turned On The Low End But Left The Tq Managment Off...
And Now It Seems The Tranny Slips Into Third......
So I Shoule Leave The Tq Managment On??
Old 10-13-2006, 04:04 PM
HeberRam's Avatar
yes.......!
Old 10-13-2006, 04:17 PM
acook's Avatar
i wouldnt even put the low end option on a stock tranny, besides i know my truck drove like crap after i put the low end on, very eratic, and the turbo barked at me more then a ****** off shitsu
Old 10-13-2006, 04:30 PM
jtskir222's Avatar
so in other words dont install bullys TQ managment..
Old 10-13-2006, 04:51 PM
acook's Avatar
Your not understanding this. Your truck, and all other dodges have a feature called TQ management, just like they have the 48RE tranny. So with the bullydog you can remove the tq management your truck has on it, but thats a bad idea. You can also turn a setting on that will give it low end power, thats not such a good idea on a stock tranny either. Probaby why your sliping in 3rd
Old 10-13-2006, 05:17 PM
quadstar's Avatar
tq management
so just to be clear, the tq management is always on unless you turn it off? but does the tq management only applies to trucks with the autos, correct?
Old 10-13-2006, 06:57 PM
acook's Avatar
Correct. Youll know when its off, it lights up the abs, airbag, and cel. Or at least it does with my BDTD
Old 10-13-2006, 07:08 PM
Bob Wagner's Avatar
smarty's tq does none of the above. 3 levels to choose from
Old 10-14-2006, 10:03 AM
HeberRam's Avatar
Talking Don't screw with the BDDL torque management!!
Acook, you have a lot more patience then me on these treads....
Bob Wagner, you always have a "smarty" answer... One of these days I'll have to try one.
Quick Reply: tq managment
