Towing with smarty tnt
Old 12-15-2008, 11:15 AM
rodriguez7's Avatar
Just curious what everyone tows with? I usually leave mine on level 6, timing 2, rp 2 and torque 4 when towing my toy hauler. But it seems like it would be ok to tow a light trailer with some quads on it on level 8 or 9. What do you all think? What kind of power can this tranny take? Level 7 doesnt seem to have that much low end. 6 does better on my truck for some reason.
Old 12-15-2008, 01:30 PM
zack birge's Avatar
I tow with beta 4.2 on sw9 up to 9k everything runs fine no problems at all
Old 12-15-2008, 03:24 PM
ddestruel's Avatar
Location: Used to be missoula, montana: Now in Sonoma County California
Running Smarty TNT on an 03 305/555 with stock sticks, stock CP3.
TNT settings are on program level 3, timing 1, pressure 1, stock TQ managment
it running cleaner than revo ever did and i have no problems with fuel pressure or rail pressure at my current levels.
with my 62/12 i rarely see egt's over 1300. On my last really heavy load 29k lbs gross i dropped timing down one step because i knew i would be pulling the back side of donner summit up out of reno into ca and that is a long enough steady climb with little to no relief for those poor pistons if i were running it at WOT, on the flats i was running 1200 degrees and heavy throttle to maintain 55 due to the head wind so i figured the grade wouldnt be very forgiving.
but otherwise i run the full timing with smarty when towing and i tend to watch EGT's for long grades i like to back out of it a hair and keep it between 1200 and 1250 but thats with 16k lbs in tow she goes up a 7%+ grade at 60 mph so i dont forsee wanting anything more than that. about the only time it really gets over 1250 is at WOT and with the advanced timing i like to error on the side of a little caution
Old 12-15-2008, 07:08 PM
DUKCALN's Avatar
I tow with sw5, rp3, tm3, tq3
Old 12-15-2008, 08:02 PM
trx
trx's Avatar
I tow 12k on level 3 rp3 tm 2 tq 2 rarely see over 1200 egts
Old 12-15-2008, 08:06 PM
35" 05''s Avatar
be carefull with that rp. dont let it go @ 20k+ constant. injectors WILL be cracking
Old 12-16-2008, 03:48 PM
rodriguez7's Avatar
Anyone else?
Old 12-16-2008, 05:39 PM
Brian Lent's Avatar
I tow 16k behind on tnt level 1 timing2 rp3 tq3 and temps on long steep grades stay below 1300. On level three it gets too hot
-PowerWagon-
12-30-2008 01:06 AM
wyocat
26
06-23-2008 01:39 PM
jmccart
06-20-2008 03:29 AM
TORQUE BEAST
13
05-09-2008 02:31 PM
molalla1ton
04-16-2008 01:08 PM
Quick Reply: Towing with smarty tnt
