towin engin temps
Old May 21, 2012 | 09:49 PM
tweeter123's Avatar
towin engin temps
i was driving home the other night hauling 16 foot horse trailer running bout 75 and noticed the truck running aroun 209 degrees i was wondering is that high or should it stay around 190 i checke the coolant and it was full and looked clean i was just curious if i should change something to help with the temp or just leave it. thanks
Old May 21, 2012 | 10:14 PM
Fiftygrit's Avatar
Mine runs between 190 and the highest 215 when towing 12k lbs.
Old May 22, 2012 | 08:19 AM
papaduck's Avatar
Mine never gets over 205. Your temps are OK but I would make sure the fan clutch is engaging. With the A/C on at speeds below 25 you should be able to hear it engage.
Old May 22, 2012 | 03:57 PM
.boB's Avatar
209 isn't bad at all. If it doesn't adversely affect fuel mileage, don't worry about it.
If you want lower temps, the first thing I would do is add a couple bottles of a surfactant like Red Line "Water Wetter", or Royal Purple "Purple Ice"
Old May 22, 2012 | 07:32 PM
vrtical's Avatar
If you want lower temps, the first thing I would do is add a couple bottles of a surfactant like Red Line "Water Wetter", or Royal Purple "Purple Ice"[/QUOTE]
Never seen or heard of this stuff, what does it do?
Old May 22, 2012 | 07:49 PM
booman70's Avatar
those temps are fine run it
Old May 29, 2012 | 05:47 PM
tweeter123's Avatar
thanks for the replys just making sure it was good thanks
Old May 30, 2012 | 12:18 AM
TxDiesel007's Avatar
mine does the same and then levels out
learned to live with it... even after a new radiator, hoses, flush, fill, and fanclutch... did the same thing...
CoastalDav
Apr 15, 2015 10:43 PM
md-rebel
MDDTR #33
Oct 4, 2008 10:39 PM
91.5 beater
Mar 19, 2008 04:02 PM
wap
Sep 23, 2006 10:08 AM
guyssets
Jan 4, 2005 06:10 PM
