Tone Ring Mod
Old 09-29-2005, 08:52 AM
Mark Hodowanec's Avatar
Tone Ring Mod
I wanted to advance my timing approx. 2 deg. by doing the tone ring modification. I thought that it was as simple as marking the tone ring, removing four bolts, & slotting the dowel pin hole. Soem that have done this described this as a 15 minute mod. Seemed easy enough, but when I crawled underneath, I could not get good access to the tone ring. Does the radiator shroud need to be removed? The radiator? What else?
Old 09-29-2005, 09:15 AM
Tiara3100's Avatar
Easy...
The fan shroud is soft rubber. I just unbolted mine from the bottom and wedged it under the fan. Plenty of room. It just looks hard, but it was real easy. Try it and you'll see what I mean.
Old 09-29-2005, 09:15 PM
bama's Avatar
when you take the two nuts off the brackets,pull the shroud back towards the front and start the nuts back on the studs.then let the shroud sit back down on the nuts...plenty of room then.........bama
Dodgezilla
129
11-18-2005 11:43 AM
Mark Hodowanec
10-04-2005 01:16 PM
BossHogg
09-30-2005 06:31 PM
Dodgezilla
09-30-2005 12:56 PM
BossHogg
09-14-2005 09:48 AM
Quick Reply: Tone Ring Mod
