Tie rod ends
Tie rod ends
All,
I just ordered the outer tie rod ends from NAPA - a few weeks back. What I received are the 4500 lb D60 tie rod joint http://tinyurl.com/2h6e25 These things are huge! Look like they are for a Peterbuilt or something
The threaded ends are over 1" in OD. These tie rod ends definitely don't fit my 93 W250! I measured the old tie rod end threads to be exactly 1" OD. Do I need to order the 3500 lb D60 tie rod ends? Any part #'s - Autozone, Napa etc. would be appreciated!
Check this web site I have had good luck with everything that I have purchaced from them and when I had a question I called the cust. service and they were very helpful. http://www.partsamerica.com/PartType...g&pgid=STERAMS
Hope this helps. Ryan
A search on Napa's website for the Moog part numbers from Logan's thread (Moog ES2010L and ES2010R) returned Napa #'s NCP 2692448 and MRC ES2010L for the left side and MRC ES2010R and NCP 2692341 for the right side. Napa's website has the option to search for parts using non-Napa part numbers.
Logan, Schandler, Free89W350 - thanks for all the help on my tie rod end post. I located the correct ends, thanks to the Moog/Napa info you all provided me with. Much Thanks!
ddestruel
Dec 7, 2008 06:37 AM
