Those of you w/ 35's or bigger
Old 06-18-2007, 11:06 PM
Graphite 6's Avatar
Howdy, Talking w/ my tire guy today, and he was mentioning that when we go with larger tires and wheel combo's, there is a tendency for the steering to want to pull to the right, I would like some opinions if this universally true or a problem with the solid axle, or none of the above. Is this a combo of heavier wheels and tires accentuating the pull in the steering?, and do the leveling kits that the quality vendors put out address this. Also I've read here that you should have an alignment ( moving the caster to like 3+*) this may not help address the "pull right syndrome". I'm going with something close to stock backspacing and offset to try to keep thing tucked in anyway. Thanks, I hope I was fairly clear.
Old 06-18-2007, 11:22 PM
Keyser Soze's Avatar
I run 37's and i have mine set to the factory alignment and mine doesnt pull, now if there is a bad crown then yeah it'll pull but other then that it drives perfect..
Old 06-18-2007, 11:23 PM
blcoonrod's Avatar
Mine does not pull at all. I had the alignment shop put all the caster they could in it. I think it ended up being like 5*. I also had to have it done at a semi truck shop. It would not fit on the racks at the regular alignment shop.
Old 06-18-2007, 11:26 PM
cbrahs's Avatar
I have 37's on mine. Road steer is a bit more than stock but expected with a 13.5 wide tire. You will be fine. Have an alignment done and run it.
Old 06-18-2007, 11:35 PM
Hooligan6's Avatar
I have 40"x15.5 on mine and I can let go of the wheel at 95mph and it's straight as an arrow.I take all my vehicles to a specialty shop that only does alignments and suspension work.
Old 06-19-2007, 06:10 AM
schv's Avatar
I suspect your tire guy has seen some trucks that had 3" or more of lift installed, without an adjustable track bar being installed.
Old 06-19-2007, 07:52 AM
UnrulyNFS's Avatar
Hooligan,
Get some pictures of that Beast!!!
Old 06-19-2007, 07:59 AM
mnmlod's Avatar
I have 37" toyo mt's on mine with no pull at all.
Old 06-19-2007, 08:36 AM
Luvnacumns's Avatar
Originally Posted by UnrulyNFS
Hooligan,
It's pretty sweet!!!! I've seen it...
Old 06-19-2007, 08:50 AM
Graphite 6's Avatar
Thank guys, It is appreciated!
Old 06-19-2007, 09:01 AM
GEN_X's Avatar
Shane
Are you holding out on us man. If you have pics of that beast please post them up.
Old 06-19-2007, 10:53 AM
cquestad's Avatar
No pull...or steering drawbacks at all on mine...
Heck...it is better than stock now. 37 x 13.5's with 5" lift.
DSS...good steering stabilizer and a "correct" alignment with 4 or so degrees of caster...rock solid.
Old 06-19-2007, 11:17 AM
nriver's Avatar
no problems on the old 35s or the current 37s
Old 06-19-2007, 05:02 PM
PWT05Dodge's Avatar
I love my 37"s, and I probably have the least amount of modifications on my truck out of all these guys (for now). Straight as an arrow.
Old 06-19-2007, 05:06 PM
Pooter's Avatar
No problems with my 35s, 4.5" lift, stock steering dampner.
Quick Reply: Those of you w/ 35's or bigger
