terrible fuel mileage
Old 11-08-2006, 10:16 AM
smokindodge1996's Avatar
help truck is costing me an arm and a leg on fuel i have chenged fuel filter airfilter and checked air pressure i am lucky to get 10 mpg i used to get about 17 or so around town. i noticed it before the ulsd switch and it got alot worse with the new diesel so i started using bio from the sinclair station and its a little better but still not as much as it was about 6 months ago truck has 245,000 on it and has power runs good just terible milage
Old 11-08-2006, 11:24 AM
TxDiesel007's Avatar
A good start
replace the overflow valve on the truck, if you havent already replace teh fuel filter canister, and im sure about the filter at the bottom of the truck, the prefilter, that probably hasnt been touched at all. The prefilter could use changing as well, U might also wanna check for fuel leaks... see if that gives...
Rick
Old 11-08-2006, 03:06 PM
displacedtexan's Avatar
Is the performance the same? It's not real likely, but the timing could have slipped, but if that was the case you would see a differnce driving the truck.
Old 11-08-2006, 06:31 PM
Earthmover627's Avatar
i agree with TXDiesel my truck got 9 mpg until i put a new prescreen filter and a overflow valve now it runs like a new one
Old 11-08-2006, 07:38 PM
2500's Avatar
my 97 CTD was leaking from fuel tank screw-on top. had to fab a long strap wrench to tighten.
when I'd fill up all the way, it'd leak a few gallons
Old 11-08-2006, 09:01 PM
somis13's Avatar
I got terrible fuel economy with the ulsd also. but the guys are rite, prefilter and overflo valve are fairly cheep. also dont overlook any leaks
Old 11-08-2006, 10:25 PM
kawi600's Avatar
My mileage went from 17 to 10 once the ULSD hit the pumps. Dont know if this is ULSD itself, or the winter blend.
Old 11-08-2006, 10:30 PM
Captain's Avatar
ULSD made me lose 1-2mpg and winter another 1-2. You seem to be losing alot more then that though. Can someone explain this pre filter and overflow valve to me a little more? might be something i should stock.
Old 11-08-2006, 11:11 PM
pre filter got changed no to long when i had to install an new lift pump also i have the screw on filter for the fuel nothing else to change there no fuel leaks put truck on lift at work to change the oil tonight and found no leaks well fuel anyway on the bottom or the top my tools to reset timing will be here tomrow so i will check that and restet the timing on saturday at the shop i need to check my vavle adjustment but i don't realy think that would cause a big loss in fuel milage
Old 11-08-2006, 11:13 PM
oh yes forgot my truck also has a clicking noise when it runs if i recall right couldn't the overflow vavle cause this?
Old 11-08-2006, 11:25 PM
Valve adjustment wouldn't cause that much of a drop. And your truck would not be running to well if the timing had slipped that much, I was just throwing that out there...
It looks like you need an overflow valve.
Old 11-08-2006, 11:29 PM
well i will order one when i get to work tomrow and put it in and see hopefuly thats all it is
Old 11-09-2006, 07:09 AM
2500's Avatar
my mileage for highway went from 22 down to 17 with new fuel.
last fillup with lots of in town mileage was the worst ever at 13
where's the overflow valve and pre-filter located?
Old 11-09-2006, 08:44 AM
waldersha's Avatar
Thanks to infidel for the pic of the overflow valve.
You may have to grind the notch a bit to get the old one out. Pretty simple job if you don't lose the washers. Takes about 5 minutes. Don't bend the line to get it out though, makes it terrible hard to get lined up again.
The prefilter is located inside the fuel preheater assembly. Look to the immediate left of the lift pump and you have the assembly. Takes a 17MM?? wrench to open it up (from the bottom) and the screen is inside.
Old 11-09-2006, 03:21 PM
Teddy Bear's Avatar
Have you checked for boost leaks? Just a thought.
Quick Reply: terrible fuel mileage
