Tap or not to tap????
Old May 24, 2007 | 09:40 AM
5.9Shaker's Avatar
I havent seen to many people tappen the vp's but I wanted to know the benafit and what I need to do it. Thanks
Old May 24, 2007 | 02:26 PM
zulusafari's Avatar
You need a performance module that needs to tap the VP44 pump wire for more fueling. Any heavy fueling box will need to tap the pump, either with a t-tap, posi-tap, or a stealth cover. My Quadzilla Xzillaraider taps the pump, as can the Edge Comp, Juice, etc. I Recommend the stealth cover for a positive connection, or soldering the connection (I am terrible at soldering, though) to the pump wire. Do not believe that using a stealth cover will save your VP-44 warranty, unless your builder specifically ok's tapping the wire or using the cover. I hear they are very well aware of the covers and know what to look for and how deep to get it to discover tapping the pumps.
Old May 24, 2007 | 02:27 PM
zulusafari's Avatar
I forgot the benefits: Depending on the box, the smile from ear to ear will be very difficult to remove everytime you move the vertical pedal on the right!!!
Old May 24, 2007 | 05:33 PM
Ground Shaker's Avatar
I have run both and I like the stealth cover. Its alot cleaner look and alot better connection IMO. For the price it is, I think its worth it if you want a nice look and good connection.
Old May 25, 2007 | 01:33 PM
5.9Shaker's Avatar
Thanks I did not understand how it worked or what I needed to do so I can take advantage of it.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
jdr160
15
Nov 14, 2007 12:16 PM
alto22
34
Feb 16, 2007 09:28 PM
Hoss
Apr 11, 2006 11:37 PM
