Taller TIRES
Old 01-16-2008, 06:18 AM
levigarrett76's Avatar
Taller TIRES
HAS anyone found a tall skinny 17" E rated tire yet?? Such as a 255/80/17?? MY generals are almost halfway gone and i would like about a 33-34" tall 10.5" or less wide tire. I cant see spending all the money for 19.5's just to lower my ratio a bit
Old 01-16-2008, 06:41 AM
kry226's Avatar
I think the Toyo 285/75/17E is the best you're going to do right now.
Old 01-16-2008, 08:25 AM
Rollin' Smoke's Avatar
not much out there.....I looked and looked but since I dont haul that heavy so I just went with some load D nitto's
Old 01-16-2008, 11:53 AM
This sucks....i dont want a wider tire, dont want to change to 3.42(cost too much) dont want to put in the newer g56 with the taller OD ratio. COME ON tire companies offer us a tall skinny tire
Old 01-16-2008, 01:26 PM
Texan1983's Avatar
im with you on that, i don't know why everyone wants taller and so much wider tires. i would love a 255/85/r17 that would be awesome. little more clearance, not as much affect to the MPG's
hell even if there were more options like 265/75 or 285/75 (toyo is the only one on that one.)
Old 01-16-2008, 01:36 PM
04dodgeHO's Avatar
Can you change the rims and get there? Like an 18 or a 16? I know the cost of the rims etc but I was just wondering?
Old 01-16-2008, 01:46 PM
brakes wont fit with the 16's!
i like to keep my fuel economy as high as i can, so i dont have a use for a tire wider than say 10"
ive contacted every tire company, michelin, firestone/bridgestone, maxxis, goodyear, kelly, toyo, cooper, bf goodrich, general....all of them more than twice and half of them wont even give you the time of day!!
fords run 17's as well as dodge....have been for more than a few years....if one company would put one out there it WOULD sell ocne the word got out
Old 01-17-2008, 02:18 AM
chipmonk's Avatar
super swamper (interco) is the only company i've found that makes a 34x10.50x17.
Old 01-17-2008, 10:15 AM
Rednecktastic's Avatar
I think you'll need a wider tire to go with all the height to keep the load rating as good as the companys want them.
This is just a guess....
Old 01-17-2008, 12:13 PM
checkster's Avatar
doesnt bfg make a 35x10.50-17?
Old 01-17-2008, 01:00 PM
hump's Avatar
Toyo A/T
Toyo A/T 285/75/17 is 34" tall & 11" wide.....
[IMG][/IMG]
[IMG][/IMG]
Old 01-17-2008, 01:13 PM
bfg makes a 33x9.5 r15 and 33x10.5 r15 in the all terrain
Im going to look into that toyo, it looks nice and narrow in those pictures...i just wonder how it fill fit on a stock DRW wheel
Old 01-17-2008, 03:24 PM
haulin-rv's Avatar
To run that Toyo I bet you will have to run spacers to avoid rubbing. I am with you, I would love a taller tire to lower the rpm's a bit on the highway. I have looked everywhere too, and found nothing.
Old 01-17-2008, 03:46 PM
Anyone heard of these?
http://www.michelintruck.com/micheli...o.do?tread=XCA
rated at 2600 lbs at 75 psi on a dually..??
first load range "D" ive seen thats good to 75 psi
Old 01-18-2008, 11:09 AM
wow that shut everyone up, haha
those tires are 249.00 on tire rack....
anyone have pictures/info on running the 285/75/17 toyo's on a dually....If the rears wont touch each other without i spacer that would be perfect for me!!!! i got a feeling the will touch loaded?
Quick Reply: Taller TIRES
