Tail / Brake Lights
Old 01-27-2008, 02:16 PM
lawnman757's Avatar
Tail / Brake Lights
I am having problems with my Tail / Brake lights sticking on my truck. The brake lights on the rear are stuck on and the light on the dash is lit up. What is throwing me off to start the trouble shooting is that the 3rd brake light does light until I hit the brake and goes right off when I release the pedal. Also the stuck on brake lights also go off when i turn the key off, where if you hit the brake pedal with the key off all 3 light up. Where do I begin? Thanks for the help.
Lawnman757
Old 01-29-2008, 09:07 AM
lawnman757's Avatar
any suggestions?
Old 01-29-2008, 09:17 AM
Foxborough's Avatar
As far as the brake light staying on, my truck did it when I first bought it. Just above the pedal where the switch is I put one of those sticky felt pads on the plunger. You know one of those pads you put on a dish so it doesn't scratch the table. The plunger is not adjustable so just put a spacer on it. You could go to a dealer and get it fixed also, but I have had no other problems 2 years and still going. I have read that some of the older trucks get come corosion on the tail light bulbs causing the sensor to believe you have a bad bulb.
cLAYH
19
03-26-2017 06:47 PM
Troym61
02-11-2009 01:48 PM
Patriot2500
06-25-2008 08:47 PM
rdmartin108
08-19-2007 08:06 PM
CHarlan
08-06-2003 08:40 PM
Quick Reply: Tail / Brake Lights
