Tach & a/c stoped
Old 09-18-2011, 06:33 PM
roadrage1's Avatar
Tach & a/c stoped
Like I said the tach quit about an hour ago and I got to reading on here and read that the crank sensor will cause that and the ac to quit,went and checked a/c dont work now...so am I looking in the right dirrection with the crank sensor?
Old 09-18-2011, 07:27 PM
VICIOUS FISHER's Avatar
yes
Old 09-19-2011, 03:20 PM
roadrage1's Avatar
allright cool....does it hurt to drive it till the new one comes in?
Old 09-19-2011, 05:44 PM
cromulius's Avatar
Not sure about hurting anything but mine was the ess a little while ago. make sure its not just out of adjusment before you buy a new one.
Old 09-19-2011, 08:50 PM
steveh1155's Avatar
Don't know about the 98's, but when the ESS went out on my 95, I had no alt charging either.
Old 09-19-2011, 09:52 PM
roadrage1's Avatar
yeah i checked the adjustment it was a no go, and yeah i forgot to add that i was not charging,i thought at first it was just the gauge but turns out it aint charging,soo i guess ther the same.
Old 09-20-2011, 07:43 AM
patdaly's Avatar
Another thing to check is the connection to the sensor, sometimes corrosion, sometimes oil ( if you have a crusty engine like mine ) can short across it, might try disconnecting and cleaning with contact cleaner ( or brake clean if you are frugal ).
wmbthe4
05-03-2011 04:15 PM
stagedriver
11-20-2009 08:16 AM
stagedriver
11-17-2009 11:54 PM
strokenmechanic
09-27-2008 04:53 PM
dansram
11-02-2005 06:54 PM
Quick Reply: Tach & a/c stoped
