Starter Contacts?
Old Sep 17, 2011 | 01:34 PM
R Walter's Avatar
Starter Contacts?
The truck is the No 2 in my signature... 96 4x4 manual transmission.
The truck had been running fine this morning and I returned to the house. I went to start it again and it started up and I heard what sounded like a loud carpet vacuum cleaner running under the hood in addition to the sound of the engine.
I sat for 10 seconds trying to figure out what was going on and then tried turning the key off. I turned the key off but the engine continued to run with the same sound continuing from under the hood. I switched the key back on (without turning the key all the way to activate the starter). About 20 seconds later the 'vacuum cleaner' noise stopped and all I heard was the normal engine noise. I turned the key off and the engine shut off.
I sat there puzzling over this for a minute or two and then tried starting the engine again. It started normally and ran fine. I went out and drove it on a few errands. The engine stopped and started fine without problems.
Any ideas???
Old Sep 18, 2011 | 09:45 AM
cj360trider's Avatar
cud be a bad starter or even a sticky starter relay. you wud need to duplicate the problem again and pull the relay to if that changed anything. if it quit when u pulled the relay good bet its the relay if not then definitely ur starter
Old Sep 18, 2011 | 01:21 PM
patdaly's Avatar
Check out fostertruck.com pretty sure you had stuck starter contacts.... It will only get worse.
That sound you heard was your starter staying engaged.
Old Sep 18, 2011 | 04:50 PM
dieselinthemorn's Avatar
I had the same thing happen. Replaced the starter solenoid contacts and haven't had an issue since the. Bought my kit from Geno's garage...$30 plus shipping. Good luck
Old Sep 19, 2011 | 09:50 AM
infidel's Avatar
Take care of it soon even if it doesn't act up again.
If the contacts stick it can toast your pricey shutdown solenoid, melt wires and even start a fire.
Old Sep 20, 2011 | 09:13 PM
R Walter's Avatar
Thanks all. I've got starter contacts from LarryB's on order.
Old Sep 20, 2011 | 09:16 PM
BC847's Avatar
1st Generation Admin
This may help . . . . https://www.dieseltruckresource.com/...-t141395.html?
buckman361
Nov 13, 2008 09:54 AM
apache
Feb 6, 2005 10:25 PM
redramnc
Aug 3, 2003 12:03 AM
doodah
Jun 3, 2003 12:16 PM
MJR
Mar 16, 2003 08:26 PM
