Tach in a 96 Gasser
Old Feb 17, 2004 | 11:12 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Tach in a 96 Gasser
Hello guys i have a 96 2500 with the 360 and need to install a tach and i was wondering if there was a plug under the dash that all i had to do was just plug the tach in and mount it?
Old Feb 18, 2004 | 10:53 AM
Lil Dog's Avatar
I had a 96 360 as well and I had an aftermarket tach. I tried to find a wire under the dash from the pcm but couldn't get a signal. The wire is Grey/light blue stripe and is in the harness under the hood but I could not trace it into the dash. I did not find out about the Grey/blue wire till I already spliced the coil wire. So you could tee into that one and see if you get a signal on the tach
For me I just ran a wire to the Black/grey signal wire going to the coil. The Green/Tan is the ASD circuit wire from all the injectors and the coil, +12V running, so its NOT the one to tap.
Hope this helps.
J-eh
'Mad Max'
May 9, 2011 01:14 PM
mytrucksaslug
Jan 1, 2008 10:29 PM
jlells01
Jan 31, 2003 11:09 AM
bulthisl
Nov 28, 2002 01:26 PM
NWDave
Nov 24, 2002 09:25 PM
