Suggest a turbo for me please..
Old Apr 9, 2008 | 11:48 PM
THURENfab.'s Avatar
Here's my needs..
- I can NOT have any slower spooling than stock. I need to drive as responsive as I can. This is my most important need..
- Need a few hundred degree drop in EGT
- More power wouldn't be bad haha!
Thank you!
Old Apr 10, 2008 | 12:12 AM
Stainless's Avatar
Do you plan on injectors or dual pumps in the future? Are twin possible down the road? With an auto you will want and smaller turbo, I have seen the HTT 62/13ss run amazing on my buddys truck that is where I would look first. Just give HTT and call and they can help you pick out what fits you best. Good luck!
Old Apr 10, 2008 | 12:32 AM
XLR8R's Avatar
With those requirements, Don - you need to go with a 62 (I like the HTT stainless too).
Old Apr 10, 2008 | 12:35 AM
EBunger's Avatar
Hey Don, what do you have for gears? I have 4.10s with my 37s and love'em, perfect tire gear combo I think. You need to see what rpm range you operate in most and what egts you want reduced most ie; peak egt or cruise egt or tow egts. In my experience a 62/65/12 will be best for towing and cruise but from about 1700rpm and up a 62/71/14 cant be beat with a 62/65/14 being a compromise between the two. A high dollar ball bearing turbo would be the ultimate in all scenarios from what I have read.
Old Apr 10, 2008 | 08:13 AM
haloman's Avatar
What about stock turbo/ s400 twins? That would spool very well and cool you down.
Old Apr 10, 2008 | 08:31 AM
omaharam's Avatar
It's going to spool slower than stock though.
My dad has a 64/65/13ss from HTT on his 06 and is spools pretty much like stock. I have heard that the 62/65/13ss actually spools faster than stock.
Old Apr 10, 2008 | 08:33 AM
haloman's Avatar
Wont that be offset by the ability to run more fuel than the stocker alone and making the spools similar?
Old Apr 10, 2008 | 08:44 AM
cquestad's Avatar
A 62/65/14 (HTB2) will work really well for a 500 hp truck. Cheap too...
Old Apr 10, 2008 | 08:50 AM
JCLeary's Avatar
I agree...
Or a 62/65/13ss if you want to spend a little more. Then you'll have a perfect turbo for upgrading to a baaaaad set of twins!
Old Apr 10, 2008 | 09:27 AM
THURENfab.'s Avatar
Thanks all!
I don't ever see myself doing twins, as I'll have way too much suspension stuff in the way..
EBunger, 3:73 gears. This is another reason I want all the bottom end I can get, with as little lag as possible. I'm not into drag racing, but more interested in making the power/torque curve as strong as possible, from down low as possible.
Are ball bearing turbos THAT fast?
Old Apr 10, 2008 | 09:30 AM
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by THURENfab.
Thanks all!
In one word... yes.
Old Apr 10, 2008 | 09:32 AM
soulezoo's Avatar
DTR 1st Sergeant
Don-- PM me if you want to know a little more about BB turbos.
Old Apr 10, 2008 | 09:41 AM
Fisherguy's Avatar
Okay, here's an easy one for you guys,
can someone explain the numbers in
62/65/13
I'm guessing
size of exhaust from engine // size of compressor to engine// (no idea?)
Don't they ALL have bearings?
Old Apr 10, 2008 | 09:45 AM
THURENfab.'s Avatar
So whats a nice ball-bearing turbo?
Old Apr 10, 2008 | 10:14 AM
cquestad's Avatar
Save your money...HTB2.
How much money do you want to spend? What are your end hp goals?
Your suspension stuff fits nicely around my twins...lol.
