Studs W/Stock Gasket?
Old 04-23-2007, 08:47 PM
97ramctd's Avatar
I have a blown head gasket and i was wanting to put studs and a stock gasket back in it this a good idea or no? Money is tight so o-rings and all that other fancy stuff is prolly not gonna happen. Would this work with my mods?
Old 04-23-2007, 09:06 PM
mainer's Avatar
get the orings done now... while you have it apart.... then when you have the money add the studs.... thats my advice
Old 04-23-2007, 09:24 PM
97ramctd's Avatar
with out the studs wont i just keep blowing the gasket? what exactly do the o-rings do? how much does it cost to get it done any idea?
Old 04-23-2007, 10:13 PM
ratsun's Avatar
Its your call but I agree with mainer. I would get the orings installed now and do the studs later just to save the re and re of the head twice. It is in your best intrest to have a reputable shop do the orings, if they are done wrong it will be a nightmare. However a marine gasket with studs will probably hold the power level your at if you keep your timing at a reasonable level, but are you planning on adding more power? I think PDR charges around $300 to oring a head.
Old 04-23-2007, 10:30 PM
Muddin_dude06's Avatar
I think you would be ok with just a marine head gasket and studs if you are somewhat done with mods atleast for a while. There are plenty of 500hp+ trucks just running studs without o-rings. I am holding what I have now fine with my studs torqued to 127 lb. ft. Knock on wood.
Old 04-23-2007, 11:56 PM
Teddy Bear's Avatar
I know a guy that put down 625 hp on orings, marine gasket, and stock head bolts
Old 04-24-2007, 02:29 AM
BigBlue's Avatar
I'd o-ring the head now and save up for studs later. That way when you get the studs and install them you will have a head that you will never have to worry about again.
Old 04-24-2007, 08:55 AM
97ramctd's Avatar
ok what exactly do the o-rings do? Also what's the difference between a marine gasket and a stock gasket?
i know i know
Old 04-24-2007, 08:56 AM
97ramctd's Avatar
oh yea and anyone know a good place to get the o-rings done in central mo?
Old 04-24-2007, 05:02 PM
John_P's Avatar
97ramctd:
I ran 12mm studs with a stock headgasket on my 1996 Dodge CTD for 98,000 miles with no problems whatsoever! At the time I was at about 475-480 RWHP.
A shop I would recommend to you is "Forest City Diesel" in St. James, Mo.
It is owned by DTR Member Keith Livingstone and he is a banner advertiser here on DTR. He is real close to Rolla, Mo.
Hope this helps you some.
John_P
Old 04-24-2007, 06:13 PM
97ramctd's Avatar
so many oppinions and still i dunno what to do
leeboy
12-22-2014 09:48 AM
77machomopar
11-30-2009 11:55 PM
dieselboy59
01-30-2009 03:57 PM
Quick Reply: Studs W/Stock Gasket?
