strange charging
strange charging
About a year ago I put on an external voltage regulator and everything was good till 2 weeks ago . After warm up volts would go up to 14.5 for a while and then cut out . It will keep this up about every 10 to 20 min between cycles , no ryme or reason . Put on a rebuilt alt. and same thing . Put on a new voltage reg. and same thing . Also , when in the charge mod the lights have a pulse , dim slightly then bright , in a defenite rythem . Batteries ar also new and are showing 12.7 with voltmeter , checked seperately. I'm stumped....
When it goes above 14.5 the check engine light comes on , then it will just go down and the needle drops well below 14, plus the light pulse when it is charging high. It use to stay steady just above 14 .
All the connections on the alternater , voltage regulator and batteries are clean and good , done at least twice . I'll have to check further down the line . I can see the bad connection/wire causing the up and down charge , it's the lights pulsing that has me really puzzled .
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
