Stock boost and pyro temp
Old Oct 19, 2004 | 03:57 PM
DF5152's Avatar
what are you seeing for stock boost pressure and pyro temps? and when do u start making boost? what rpm do u reach before making max boost? No boxes?
Old Oct 19, 2004 | 05:35 PM
MikeyB's Avatar
The highest I have seen with my '03 is 26psi and 1250 degrees pre turbo. Stock engine except for the airbox mod.
MikeyB
Old Oct 19, 2004 | 07:43 PM
supercharger's Avatar
stock boost is 22-23 when it is summer temps, winter temps in the 30's will run 23-24lbs, egts are 1225 on a 70-100 mph run.
Old Oct 19, 2004 | 11:40 PM
bauer500's Avatar
My truck is stock and my boost will hit 32psi and my egts crusing at 70mph at just about 2000rpms are right around 800 pre-turbo, my max egts empty have hit 1250...
Old Oct 20, 2004 | 07:29 AM
Blue600's Avatar
I've hit 34 psi of boost and 1375*F preturbo I'm running stock.
Old Oct 20, 2004 | 08:40 AM
nickleinonen's Avatar
the 555 engines will make ±25psi boost, while the 600 will make the 30+ boost
±1200° for the 555 pre turbo, ±1300° for the 600's pre turbo
Old Oct 20, 2004 | 08:15 PM
bauer500's Avatar
Hey Blue,
Did you mount your boost tube in the horn or using a boost bolt in the maniford?
Thanks,
Mark
Old Oct 21, 2004 | 07:30 AM
Blue600's Avatar
I tapped the airhorn.
Old Oct 21, 2004 | 10:12 AM
HighTen's Avatar
Will a boost gauge yield different readings between these two installation methods? I was going to go the easier way with a boost bolt but if there's a question about accuracy, I want the accurate way!
Old Oct 23, 2004 | 09:22 AM
bauer500's Avatar
I'd think that being in the manifold using the boost bolt would be more accurate, but thats just my thinking..
Old Oct 23, 2004 | 11:52 AM
Blue600's Avatar
The airhorn dumps into the manifold. I don't think there will be any difference in readings.
lessismore
Nov 12, 2010 08:50 AM
snowmanx
Mar 31, 2009 08:42 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
flashgordon
Mar 28, 2006 08:47 AM
