Steering Stabilizer Pics Please!?
Old Feb 1, 2011 | 06:18 PM
schamran's Avatar
I think I'm gonna build steering stabilizer brackets for my truck. I will use my old set of stock shock absorbers for now, just to see how well it works.
Thanks!
Old Feb 1, 2011 | 06:28 PM
rswoyer's Avatar
This doesn't show the brackets very well; I'll look and see if I have anything better.
Old Feb 1, 2011 | 06:34 PM
BC847's Avatar
1st Generation Admin
Regular shock absorbers won't work correctly in a steering stabilizer application.
The stabilizer uses a 50/50 compression/extension metering where as the shock absorber doesn't
. . . Unless I'm mistaken
Old Feb 1, 2011 | 07:14 PM
schamran's Avatar
You mean like it rests in the center of it's travel? I think it may work if I place them like the pics above, but don't get me wrong, I appreciate any input! Thanks!
Old Feb 1, 2011 | 07:53 PM
Flake's Avatar
This is correct, the valving in a shock most likely will be stiffer in one direction, not good in a steering application.
Old Feb 1, 2011 | 08:06 PM
schamran's Avatar
Do you think they would work if there were two facing opposite directions like the pic above?
Old Feb 1, 2011 | 08:07 PM
schamran's Avatar
Flake you should post up some pics of that truck of yours!
Old Feb 1, 2011 | 08:55 PM
Trooperthorn's Avatar
seems like it would.
Old Feb 1, 2011 | 09:29 PM
1STGENFARMBOY's Avatar
On a shock it always is trying to extend, on a steering stabilizer it stays where you stop without any preshure either direction.
I would be afraid if one shock was stronger than the other it would try to turn the wheels.
This is what i have found anyway.
Dar
Old Feb 1, 2011 | 09:33 PM
schamran's Avatar
OH thanks Darwin! The light bulb just turned on! I will have to see if the two shocks are remotely comparable, and if they are I'll just use them for comparison purposes to see if it helps vibration and bump steer. I don't wanna buy anything until I know that it will help my situation. Thanks again!
Old Feb 1, 2011 | 09:43 PM
David said the same thing but he was using his doctor language( since he is the 1st gen doc ) i just simpled it up a little bit.
Randy it might help a bit, but i have two new rancho stabilizers and just installed a new steering box stabilizer braket and still have the dive when i hit and uneven spot in the road, I'm gona tighten up the worm gear in the box with the jam nut and the set screw soon then i might replace the top rag joint with a u-joint, i already have the bottom one done.
I don't know what to do if those don't stop it other than cross over steering.
Dar
Old Feb 1, 2011 | 10:04 PM
simplysmn's Avatar
Trust me a steering stablizer help's Alot on a first gen if you have a lift go with the dual's
mercedeezel
13
Oct 13, 2013 12:43 AM
EdmontonCanada
Jul 20, 2010 03:57 PM
1985cucv
Jul 31, 2009 02:33 AM
Rattlerattle
Aug 19, 2008 04:14 PM
13ALPHA
Jul 8, 2008 11:31 PM
