steering problem
Old 12-31-2009, 09:19 PM
fatt's Avatar
steering problem
About a month or so ago I started noticing that if i take a left turn when I straighten the wheels the steering wheel tilts a bit to the left(about 1/8 turn) and same thing on right turns. Installed a Borgeson thinking the coupling was shot but it still does the same thing. Do i need to replace the steering box? Anyone have a solution?
Old 01-01-2010, 12:04 PM
Montana2x2's Avatar
What year truck? 2Wd or 4WD? Could be a loose steering box or cracked frame where steering connects. Worn front end parts. Give front end a good check for anything loose. That would be a start.
Old 01-01-2010, 12:30 PM
Yeah, sounds like the box is not securely fastened to the frame anymore...
Old 01-01-2010, 09:26 PM
fatt's Avatar
91.5 w250
Old 01-02-2010, 05:06 PM
Montana2x2's Avatar
I'd take a good close look at the steering box mount and the frame to start.
Old 01-19-2010, 04:20 PM
fatt's Avatar
I checked and everything seems tight. However i did notice this
http://s762.photobucket.com/albums/x...nt=11sssss.jpg
Old 01-19-2010, 06:08 PM
Holy loose u-bolts, Batman!
LanceK
13
07-14-2006 08:08 PM
ocsurf16
03-13-2006 09:24 PM
unioncreek
06-29-2005 02:00 PM
OHFarmboy
02-25-2005 11:30 AM
06-05-2003 09:27 PM
Quick Reply: steering problem
