starting and cutting out issue on 03
Old 08-12-2009, 12:09 PM
fullbore farmer's Avatar
I just put on a new industrial injection modified cp3 in the truck. ever since that it takes longer for the truck to start it has to turn over more , then it will start then die or stumble then it starts and runs good. When running it runs smother and quieter than it has in a long time. Also when the truck hits about 2700 rpm it cuts out or slows down (surges) and speeds up . Any body have any ideas what could be causing the problem.
Old 08-12-2009, 01:24 PM
ScienceOfSpeed's Avatar
what kind of lift pump do u have, stock or aftermarket?
Old 08-12-2009, 02:10 PM
farmboykjb5.9's Avatar
might have something to do with the fca
Old 08-12-2009, 02:12 PM
cbrahs's Avatar
you got a rail psi gauge? Had a 03 dually doing the same thing after dual cp3 install and it was the rail psi relief valve. capped it off and good to go.
the lift pump is a aftermarket from bd it is only a year old and the fca was brand new with the cp3
Slice
10-25-2009 09:15 PM
roughstock
03-26-2006 02:30 PM
Rganser
12-22-2005 07:53 AM
Bad Ramer Jamer
12-09-2005 06:56 PM
ozark diesel
12-09-2005 06:04 PM
Quick Reply: starting and cutting out issue on 03
