Stacks under the bed
Old 02-15-2010, 12:01 AM
Shorty25's Avatar
Hello,
Got a question. Right now my 01 cummins has a set of 5 inch stacks. Under the truck however still has the stock size exhaust which is nice in a way cuz the exhaust is split into the stacks under the bed which still allowed me room to put a tool box in the bed of my truck between the stacks. I would like to upgrade the exhaust to a 4 inch system from the turbo back and use the stacks that I already have. Is there a kit that makes it possible to split a 4 inch exhaust under the bed without relocating the fuel tank? Or has anyone else done something similar that might be able to help me out?
Shorty25
Old 02-15-2010, 06:11 AM
Load Hauler 04's Avatar
Most of the kits I have seen are ones that set in the bed behind the cab. I have seen a couple of guys on DTR that have split them under the bed and built there own system. Good Luck!!!
Old 02-15-2010, 09:34 AM
rage_blue's Avatar
I think if you get a 4 inch stack kit mainly for the y pipe you could put the ypipe under the box, just may have to hammer the pipe a little to make it fit between the box and frame, maybe a heat sheild to protect the tank? I've been thinking about doing the same thing, just haven't measured to see what it will take.
Old 02-16-2010, 01:13 PM
Shorty25's Avatar
The only thing I'm really concerned with is how tight the 90 degree bend is that goes into the stacks.
Old 02-17-2010, 06:48 AM
Joe Diesel's Avatar
a 90* 4" pipe will flow with no problem if thats your concern
Old 02-18-2010, 05:37 AM
Shorty25's Avatar
no my concern is getting the 90 to clear the frame rails and the tank
southpawslingr1
09-11-2007 07:13 PM
rockittboy
02-03-2006 12:38 AM
blackdiesel
07-08-2005 11:49 AM
PistolWhipt
32
02-19-2003 04:40 PM
Quick Reply: Stacks under the bed
