stacking bddl & edge juice
Old 04-05-2007, 10:26 PM
blackdevil's Avatar
was wondering if anyone has stacked these two with stock turbo? are there any timing issues to be worried about?
Old 04-05-2007, 10:30 PM
morkable's Avatar
it works,, but it isnt all that impressive... better off with either just a hot juice,, or going with a diablosport
Kevin
Old 04-05-2007, 11:28 PM
blackdevil's Avatar
ive heard of people blowing their engines, dont know if it's bs or not. Just wondering what should be the main concern with stacking these two?
Old 04-05-2007, 11:55 PM
morkable's Avatar
no concern,, just isnt very impressive,,,, just the hot juice will out perform that stack, or just the diablosport.
Kevin
Old 04-06-2007, 12:02 AM
973604x4's Avatar
morkable notice he has an 04.5, lots different from 03
it works but theres ALOT of timing. Its not a popular stack for some reason.
NOT for a stock turbo no matter what. Edge or Bullydog alone can hit 1400* easily.
Old 04-06-2007, 12:51 AM
morkable's Avatar
I guess I should have asked it was a power pup or a triple dog too,, that could make a difference,,, I think if it is a power pup, it wont matter what year it is
Kevin
Old 04-06-2007, 12:49 PM
CStroked's Avatar
given the timing advance what setting would you recommend running this on? i'm having this installed on his truck in a little bit, so it'd probably be good to know, haha . just an fyi after reading that sig the only thing on the truck right now for programs is the CLDL.
not to hijack, but how's the hot juice run stacked with a TST compared to crazy larry?
Old 04-06-2007, 11:19 PM
973604x4's Avatar
Hot juice does not stack with the TST. It can't.
Hot Juice stacked with Crazy Larry....well....i tried it on my truck. Hot juice on level 5, Bullydog on....TOW and timing rattle was NASTY! every truck is different, but start with low settings and work your way up.
TST stacked with Crazy Larry is out of this world compared to Juice/Crazy Larry.
Old 04-07-2007, 08:48 AM
Bham Ram's Avatar
This may be a stupid question, but is TST and Crazy Larry stacked not way to much timing?
Old 04-07-2007, 10:36 AM
rstone's Avatar
if you get the newer version of the tst it has adjustible timing feature on it so you can stack the two togather. My buddy is about to stack the juice and the smarty togather has anybody had any luck with that stack.
Old 04-07-2007, 10:38 AM
973604x4's Avatar
exactly what rstone says.
omaharam tried it. Did make any power than before he stacked the smarty.
A guy at Buda only gained 25hp from level 0-5 on his juice when stacked with a Smarty.
Havic801
11-16-2011 02:34 PM
hotrod929
12-27-2006 11:10 PM
2-Stroke
06-11-2006 09:03 PM
razor6
02-11-2006 01:28 AM
Quick Reply: stacking bddl & edge juice
