Springs or Spacers to level front
Old Feb 9, 2006 | 09:31 PM
Derek Timm's Avatar
I'm going to level the front end of my truck and wondering what is the best way to lift the front 2"? I see the sapcers are readily available but I only see a few spring kits that do the 2" lift. What about shocks and the suspension arms when the front is lifted 2"? I want the best solution not the lowest cost.
DT<*)))><
Old Feb 9, 2006 | 09:34 PM
rockittboy's Avatar
i dunno if you have les schwab tire stores in your area, but they put on a really good leveling kit with 2" spacers and shocks for a decent price. for only 2" i would say just put in a spacer and buy some 2" longer shocks. it owuld be a good time to upgrade to bilsteins. alot of guys have them here and say they really ride well. oops, i just saw your up here with me too, so you should have les schwabs.
Old Feb 9, 2006 | 09:36 PM
Cowhand's Avatar
Definitely springs....you can even get a softer spring if you want it for roughly the same price. Coil Spring Specialties does nice springs, and there are a few others that I hear do good work as well. Stay away from the Skyjacker D25's.
Stock control arms are fine...you can get away with the OEM shocks but I'd recommend going to Bilstien 5100's.
Old Feb 9, 2006 | 09:39 PM
Derek Timm's Avatar
Where is Coil Spring Specialties located? I agree on the Bilstiens - Loved them on my last truck!
Old Feb 9, 2006 | 09:40 PM
rockittboy's Avatar
at least you agreed with me on the bilsteins!
Old Feb 9, 2006 | 09:41 PM
rockittboy's Avatar
derek, where are you at in nor cal?
Old Feb 9, 2006 | 09:43 PM
Derek Timm's Avatar
I am still considering spacers for now I can't make up my mind on wheels and tires so I might go that way and save for a lift and wheels and tires. Just need to get a few more miles out of the stockers first.
Old Feb 9, 2006 | 09:44 PM
Derek Timm's Avatar
Nice truck! I'm in Windsor.
Old Feb 9, 2006 | 09:47 PM
Cowhand's Avatar
coilsprings.com
Last I heard a 2" leveling coil was around $200/pair shipped.
Old Feb 9, 2006 | 09:49 PM
Derek Timm's Avatar
THX Cowhand I'll look them up.
Old Feb 9, 2006 | 09:54 PM
Big Horn's Avatar
I bought a set of tuff country leveling blocks used from a guy who went to a 6" lift.
$80, and I installed them myself in about 90min. Install instructions are on the internet. I am still running stock shocks for now, which they say is o.k. for only 2", but I am looking into the Bilstiens for the future.
Old Feb 9, 2006 | 10:08 PM
Syndicate's Avatar
spacers and lift blocks suck! Your always better to upgrade the coil or leaf spring to the right height. Do it right the first time and you wont have to do it twice.
Old Feb 9, 2006 | 11:29 PM
DmaxEter's Avatar
I love my spacers. Installed them in about an hour and the truck rides and drives absolutly perfect. Stock shocks and no alignment. Our local 4X4 shop has a tech that has about 80,000 miles on a set of polyurethane spacers towing his rock crawlers and they have cause no problems and still look new. Just my experience with them.
Old Feb 10, 2006 | 01:12 AM
powerstrokin03's Avatar
Just a quick question what do you have against the D25's?
Old Feb 10, 2006 | 10:12 AM
Cowhand's Avatar
Poor quality spring and the coil rate is too high. Look at the wire diameter and coil spacing on the D25's compared to the CSS springs (there's a pic in my gallery).
CSS (or any other custom coil manufacturer, there's a few other good ones) uses a larger diameter wire, so the coils don't fatigue as fast, and closer coil spacing for a softer spring rate. You can even spec a softer spring rate if you want to for the same price.
My SJ 4.5" coils lasted about 2 years before they started to sag, and they always rode like . I use 'em for door stops now, I won't even give 'em away. You'll be surprised what a difference a good coil makes in ride quality. The kicker is the price difference is only about $30.
