Speedo no worky
Old 11-21-2010, 11:13 PM
bulltamer's Avatar
Speedo no worky
Well I think my vss went out on my '92 my speedo started jumping then completely quit working so I tried my spare speedo and nothing what do u guys think
Old 11-22-2010, 06:32 AM
Onemoparnut's Avatar
I had a similar problem and it was a bad wiring connection at the vss. I cleaned up the connector and put some dielectric grease on it and it has been fine ever since.
Old 11-22-2010, 09:07 AM
ppiggppenn's Avatar
Originally Posted by onemoparnut
i had a similar problem and it was a bad wiring connection at the vss. I cleaned up the connector and put some dielectric grease on it and it has been fine ever since.
x2 ^^
Old 11-22-2010, 11:00 AM
bulltamer's Avatar
Where exactly is the vss located
Old 11-22-2010, 11:08 AM
MrExtreme's Avatar
It's on your transmission for 2 wheel drive, transfer case 4 wheel drive.
Old 11-22-2010, 11:15 AM
bulltamer's Avatar
Ight thanks guys
Old 11-22-2010, 07:12 PM
Shiny's Avatar
So my truck kind of does the same thing... works great for a bit then bounces around, doing 35 m[h it will read 110, then will go to zero, the trans shifts up and down. you guys figure its the same thing then?
Thanks!
-Shiny
Palmetto_kid
07-02-2005 07:56 PM
2 busy
04-26-2005 09:43 PM
CTD NUT
13
04-01-2005 06:40 PM
zack_76401
03-04-2005 11:37 AM
andyr354
12-17-2004 01:48 PM
Quick Reply: Speedo no worky
