spare tire removal problems!!! need help
Old 06-19-2009, 09:10 PM
1985cucv's Avatar
ok im stumped here. i got the rods out 3 normal rods and one with a hook and i cannot get the thing to latch. with the hook end in i cannot get the thing to slip in so i can start to crank i am truly stumped here any help would be great
Old 06-19-2009, 09:28 PM
txpig's Avatar
Use the square end not the hook.
Old 06-19-2009, 10:05 PM
RamWheelsBy4's Avatar
Yes as stated above the rod with the hook end is not used. Put two of the other ones together. Use the squared hollow end to fit over the rod on the pulley. Slide the lug nut tool on the flat end and turn.
Old 06-19-2009, 10:47 PM
1985cucv's Avatar
tried it that before and it doesnt work!!!!! maybe something is jagged up? thanks for the responses though
Old 06-20-2009, 12:57 AM
Administrator/Jarhead
madhat's Avatar
I would look to see if there is anything in the female end of the lowering system. Is it turning? Will it stop if you tighten it all the way? The tire might me stuck to the frame, you could give it few licks with a hammer after you've tried loosening it a little.
I see you're from WI, I would be concerned about the road salt and corrosion.
Old 06-20-2009, 05:15 AM
Dodgezilla's Avatar
The little winch broke on my 03 and I had to pull it apart and fix it. I would try jarring the tire loose and if that doesn't work then try prying down on the tire with a crow bar or something similar while you are cranking. You may have to replace that winch. I'm going on vacation this weekend and on my way I am picking up some parts from a wrecked PowerWagon. If you want, I could ask him to pull that little winch off the truck for you if yours is truly broken. I'm not sure what he would want for it though. Maybe $20-$30......
The hooked rod is only for pulling the hubcaps off....
Old 06-21-2009, 02:06 PM
1985cucv's Avatar
yeah i realize that now i am going to try and get it off today.
Old 06-21-2009, 05:08 PM
jbham's Avatar
Maybe it has a spare tire lock on it. If it does then look for the silver rod.. which is the key.
Old 07-07-2009, 06:46 PM
1985cucv's Avatar
still cannot get this thing out does anyone have any other suggestions if not i will be cutting the bracket that holds the tire on and rewelding it. thanks
fatt
05-12-2009 01:33 PM
Boatnik
11-06-2007 07:52 PM
NoSparkplugs
07-02-2007 04:46 PM
4RnrRick
02-27-2007 11:25 AM
I PASS GAS
05-12-2006 11:19 PM
Quick Reply: spare tire removal problems!!! need help
