southbend ofe is in... ?? now.
Old Dec 14, 2007 | 05:43 PM
j's Avatar
j
new clutch seems to be a little loud above 2000 rpm's. not sure how to describe the noise, kinda like a low moan. is this normal to be loud at first? i thought maybe it just needs to break in a bit.
Old Dec 14, 2007 | 06:51 PM
Dodgezilla's Avatar
I never had any noise like that with mine. I've put about 12000 miles on it now....
Old Dec 14, 2007 | 07:28 PM
stock600's Avatar
my only noise is at idle with the new sb clutch. The disk rattles, it goes away at about 800 and up rpm- right off idle. Just sucks like in drive thoughs or bank tellers etc....
Old Dec 14, 2007 | 08:24 PM
M1AM14SPUR's Avatar
Question
Mine has a rattle to it too when the cluth isn't pushed in. Also It doesn't grab when I try to build some boost for a harder launch. Is that normal?
Old Dec 14, 2007 | 09:28 PM
Dang's Avatar
I have a slight whine if I lug it in a gear. Not a sound I heard with the stocker.
Old Dec 15, 2007 | 01:04 AM
j's Avatar
j
hmm... well i guess ill just keep an eye on it
Old Dec 15, 2007 | 05:31 AM
Dodgezilla's Avatar
Yes, if you lug the engine you will get that noise but that is normal....
Old Dec 15, 2007 | 06:06 AM
dogger's Avatar
SBC OFE clutch
I installed one on my '03 and have not heard any additional noise. It is definitely more pedal pressure than the stocker. Nice engagement and I hope it is that way when towing.
I eventually going to replace the stock hydraulic clutch kit with the upgraded unit from SBC and I am having a heck of a time getting the clutch interlock electrical connector apart under the dash. I have tried pulling, pushing, and prying that little tab on the connector and I cannot get the connector apart. Any recommendations.
L8r,..........dogger
Old Dec 15, 2007 | 07:22 AM
Tree DR's Avatar
There is a difference between the OFE and the Con OFE right? One has springs and one doesn't? If you hav the Con O does if have a tendancy to grab and jerk since it doesn't have springs?
Old Dec 16, 2007 | 12:18 AM
kuhkuhkyle's Avatar
the o, ofe, and fe are the materials used. O= all organic materials used. OFE= organic on one side, and feramic on the other. FE= all feramic used.
ahopper
Oct 30, 2008 12:36 PM
sootindiesel
Apr 14, 2008 09:05 PM
sootindiesel
Oct 24, 2007 05:14 PM
sootindiesel
Sep 5, 2007 01:21 PM
Dieselcamper
Jun 30, 2006 10:21 PM
